Kyosho Touring Car
#751
Car 3 is more proven on carpet. Last year at the US Indoor Champs Josh made the main and the car looked very good. Keep in mind that was with plastic and homemade parts on it. Who else at Kyosho has tested with a Cyrul designed car? I have seen several of cars 1 and 2 being tested but why not car three??
Chris
Chris
#752
Chris is right, we need to see more than Josh testing his car. It works great here at CEFX and this latest holds more corner speed than before. Can't wait to see it in Vegas and Cleveland this year.
Tim
Tim
#753
Hi guys,
Very good input from everyone, but i want to let you know that Cyrul's Kyosho prototype is made for him and might suit his drive. When it comes to design a car and then sale it, we have to consider 3 things.
1- The car has to suit most of the drivers out there
2- The car has to be trabe all over the world
3- The car must and should handle in any hands, newbies as expert...
For the fact there is a very little chance to see one day Kyosho produces Cyrul's car.
By the way, Car 1 on the picture is the final TF5 Stallion. Mark Pavidis ran an out of box kit.
The TF5 Stallion sku-30022 and pre-order will be available in the next couple of day at the very good shops..
Thank you and see ya.....
#754
Originally Posted by J.Yves
Hi guys,
If you listened to the interview with Mark Pavidis on the Orion website during the worlds, Mark said that there was alot of Cyrul's design in the Stallion. He thought that Cyrul had some "pretty ingenious" engineering in his design. No he hadn't driven it because only one exists. Why? Cyrul has the only car because the politics of the design process has not allowed anyone else to have one. Too many hands in the pie. Other than Pavidis who is a very talented driver (did not run an out of box kit, btw) - Cyrul was the next highest Kyosho finish. I think the car has proved itself on both inside on carpet and outside (Stallion has not). Too bad if Kyosho lets this slip through their fingers. I agree with Roly - hopefully Cyrul can make a conversion kit.
#755
Stallion is proven on carpet, it has done the A at some of the major international races in the hands of Adachi, that's a fact. And Pavidis's car is what you'll get out of the box. Also what do you know about the design policy at Kyosho, do you work for them ?
#756
By the way, did you dream that interview ? I can seem to find only Andy Moore's interview on the orion website...
#758
Originally Posted by TRF415boy
You're making a fool of yourself.
OH Boy there you go again typing away and not knowing what you are talking about. When Chris say's proven on carpet he means with FOAM tires. Internationaly they run rubber tires this is a HUGE differance. Listen we know Kyosho is building car 1 if you rember back a few months when you posted that Kyosho was only making the shaft car when your "VERY GOOD SOURCE" at Kyosho told you so. So we know he and you where both wrong (if he even exsists).
So the next time before you make a fool of yourself please know what you're talking about.
Roly
P.S. Let you source a Kyosho know that we'd like to see hex heads instead of phillps Thanks.
#759
Roly
Roly
PS: they already have on the TF-5, who's making a fool of himself now ?
#760
What reliable source on page 5 said the shaft car wasn't to be released ?
Right let me clarify everything. The TF-5 is the shaft driven car that Adachi has raced at the JRMCA and will be released in may. It should be available all around the world by then (I know it will be available in Europe right away, can't comment about the US as i simply don't know).
#761
Originally Posted by Turbonium
which time?
#762
Roly
Roly
Hi all,
I read this thread from the first day and i know quiet a few on this thread, even some Kyosho employees or Kyosho good lads who wrote a few things...
But i see you,PaintingRoly, all the time, telling people that you know much more than anyone else.... You have seen that or you even know Cyrul plans... So good for you but so bad for the public........
I must say that most infos you put in this thread are wrong, i don't know where you get those info but change source...
I don't want to defend TRFBOY, but i have to say that his info are good even sometimes so good that i thought he was working at Kyosho... But i know he does not...
By the way, did you ever built a Kyosho TF5, because there isn't any phillips screw in the kit and wont have any in the Stallion. So get off of the thread and the "source" tells you better for you to buy a Nikko instead of a Kyosho.
Kyosho aim and exist by true Fan............
Thank you
PS: Be friend not a fool!!! I well know TRFBOY source's and i can tell you that he might be standing behind you and then kick you out of any Kyosho events or team,...or even more....It's just toys we race so think about it...
#764
Trader Rating: 32 (100%+)
On Josh's car how is he able to not run a full castor block and only use an upper tie-rod and not a full upper arm to hold the steering knuckle in place? His car look really good I wonder if it will be made into a kit or just something hes playing with?
#765
