need some measurements from an XO-1 please
for a project I am working on I need to know the distance between the mounting holes on the spur gear, also what size is the output shaft that spur sits on? If you could, provide me of the angle that the triangle forms when drawing a line from each mount point on the spur I would appreciate it. data can be in imperial or metric. Thanks a bunch
no one can help? its just some measurements...
can get you measurements tomorrow .. the spur connects to the cushdrive assembly which then goes onto the driveshaft and differential
No idea what XO 1 is but given that there are three bolts holding the spur on, for balance reasons I can guarantee you the angle you want will be 60 degrees.
