Tamiya TA05 Touring Sedan
#9481
I agree, my car is pretty good just the driver needs to be dialed in . IMO, i wouldn't say that a cheaper car can't hang with a expensive car unless your planning on running MOD. then i would have to say your more correct in this aspect. there are plenty guys running all high end cars and i'm just about as fast as they are with 05. So not sure.
#9482
I am extremely happy about my TA05R, for $200, this car can hang with $400 plus cars, indoor carpet and outdoor asphault. I am mainly using this car for 13.5 but I have run this car with 4.5 on a 1/8th track and has ZERO problem of it.
So...getting the IFS and run with the big gun is absolutely do-able. It is all about setting, tires, skill...all together. But if running with the same driver, TUB is always a TUB...they tweak VERY VERY bad easily. My tub is like tweaked in 4 different direction that I can no longer do a correct ride height unless I invest $70 for the carbon material tub option. Since I am using this car for outdoor clubracing, I don't care much about those detail and just concentrate on the tires, motor, esc and driving skill...
416 is always 416, just like all the top of the line chassis...just like my Mi3 and E4RS, they are better then my TA05R, however, depends on WHERE I am racing the TA05R, that "BETTER" can be very very slim sometimes.
#9483
For me, the TA05R was always a very stable and consistent car. And great value.
That stability was a blessing and a curse though - some days when the grip was low it made getting a good result easy. Other days when the grip came up I was left searching for a bit more steering and corner speed that I could never find.
#9484
The IFS-R is a great club level car, the IFS isnt really exploited fully (TTech preditor dtms has full inline front and rear suspension) but its certainly not a novelty.
#9485
Depending on the type of drift tires you're using ofcourse...
You could possibly use the same FDR on both surfaces, however if your drift tires are generating some grip on the asphalt then you'll want to run a higher FDR(HIGHER NUMBER) by using a slightly smaller pinion which will allow the drivetrain to spool up faster and break traction more easily.
#9486
which chassis upgrade
My spare ta05 suffered a major accident and the tub chassis is ruined. So I', thinking of replacing it with two deck up one.
So, which one is the best? (I race indoors on Carpet 19t, so stiff is good)
It seems there are quite alot of them
Xenon
Tech Racing
kawada
Penguin
Flap
Crest Racing (saddle pack)
3 racing V1
3 racing V2
what is the difference between the two versions of the 3 racing chassis?
also if someone has a used on they want to sell PM me.
Cheers
Xenon
Tech Racing
kawada
Penguin
Flap
3 racing V1
3 racing V2
Cheers
#9487
Hi Quatmix, I am wondering the same thing. But add Square to the list, as they have a conversion too, haha!
Here is a review on the (I believe) first version of the 3 racing chassis. Albeit it is a review from a drifter, you'll get an idea of the chassis, as it is still very in depth.
http://www.drccentral.com/old/ta05review.html
I don't know anything about the other conversions, so sorry I can't help there. I just remember reading that review, so hopefully it will help you out
#9488
Xenon
Tech Racing
kawada
Penguin
Flap
3 racing V1
3 racing V2
Cheers
Xenon
Tech Racing
kawada
Penguin
Flap
3 racing V1
3 racing V2
Cheers
Hi,
I recently put a Xenon chassis on my TA05R and I was quite impressed with it. The finish seems to be as good as Tamiya and it retains all of the regular 05 parts unlinke the 3racing or tech kits. I have heard however that the 3racing chassis is good for carpet as it nice and stiff (thick carbon). I run outdoor on rubber tyres and have tried both the 3 racing and Xenon on a 05R. I felt the Xenon was better for me but I guess it up to personal taste and track condition.
Cheers,
Steve
#9489
Xenon
Tech Racing
kawada
Penguin
Flap
3 racing V1
3 racing V2
Cheers
Xenon
Tech Racing
kawada
Penguin
Flap
3 racing V1
3 racing V2
Cheers
It's a good price and very durable, but probably discontinued now the V2 is out.
The V2 has the cell slots machined closer to the centreline of the chassis (makes the cars steering sharper afaik) V2 chassis also comes with a custom 3racing layshaft (V1 didn't).
No complaints with mine, and 3degrees rear toe in and a spool gives LOADS of steering. so much that sometimes you need to dial some out on the transmitter. (Sorex 24/lower shore rating foams).
Mine feels good with TRF shocks indoors with 3 hole pistons, hasn't tweaked either as both the top and the lower chassis is 3mm.
Very capable club level car imho...
#9491
I measured the nessesary differential circumference then cut some circles out, but then the middles too, obviously to allow the outdrives to slip over it.
If you look close enough, you might see it in this picture
Failing that, JAAD sell differential covers for 35t differentials. I think these would fit the '05....
something here should fit, check out the spec's of each I guess... You'll have a part number if nothing else...
http://demonpowerproducts.co.uk/adva...8cf66943768cc3
hth
#9492
ok, i need just a little more help from you knownlegde kings out there. The car is pretty dialed in right now. But could use just a little more on power turning. suggestions?????
also, what motor do you guys run for 13.5?
#9494
I am not a club racer, but I do know a little bit about tuning:
Try some toe out in the front, and get rid of any toe in you might have. I would imagine that the softer springs are in the front, the more mechanical grip you'd get, so try lessening the spring rates slightly in the front. Do you have the TRF dampers?
Hey guys I just got a TA-05 used. However the lower arms have A LOT (1cm) of movement front and back along the hingepin... is this normal?
#9495
1cm? Or did you mean 1mm? Huge difference between the two.
1mm isn't much, just shim it.
