Tamiya TA05 Touring Sedan
#9363
Anyone use the (#53970) Ball Differential Protective Seal? Is it recommended? I just got a new TA-05R.
cheers!
cheers!
#9364
Stocker yes I've run them, they do help to keep dirt out and the diff stays smooth for longer.
#9365
Thanks Skitee! Gosh, you do have many Tamiyas!!
#9366
TA05 cars for sale
hey everyone
im getting rid of my entire TA05 fleet. check it out! HUGE FIRE SALE.
http://www.rctech.net/forum/showthread.php?p=4558062
#9367
... if only I was in the US
#9368
Acer racing sells 3mm ceramic diff balls for $13 in packs of 10...
http://www.acerracing.com/products/3...ls-773-66.html
#9369
They are highly recommended. They keep dirt out of the diff like you wouldn't believe. One trick that isn't mentioned in the manual is to coat the outdrives with diff grease where inner radius of the seal touches/comes-close. This will keep the seal from sticking to the outdrive and getting ruined...
#9370
Combo
Hi guys, newbie here
What combo of SPUR and PINION GEAR can you suggest in brush 23t motor for my TA05? Im using NIMH bat.
thanks in advance to all
#9371
If you use a spur/pinion combo that puts the final drive ratio in the mid 7's (7.5:1), it should be pretty fun to drive.
It really depends on what you want to do though. If your just bashing, you will want to go as big a pinion you can while keeping motor heat down.
If your racing, it will all depend on how long of a straight and how slow a turns. Of course the idea is still to keep motor heat down. Smaller pinion = less heat & more torque. Bigger pinion = more heat & less torque...
#9372
#9373
Does anyone use the black (or blue) motor heatsink? Is it value for money or are there better ones like those with a fan? I'll probably run brushless 13.5 and above.
#9374
#9375
thanks again
