Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 07-04-2007, 09:22 PM
  #7996
RandomFellow's Avatar
Originally Posted by macnkitty2002
i'm getting my 05R on Thursday, is there anything i should be aware of when building the kit?
See the below notice:
http://www.tamiya.com/english/info/070522.htm
and this post:
http://www.rctech.net/forum/showpost...postcount=7707
RandomFellow is offline
Old 07-04-2007, 09:45 PM
  #7997
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Frost99999
So the stock whites arent super stiff?!
Good to know!
If you look at the end of the -R springs (the white ones), they have a yellow mark on them. They're from the limited edition white spring set...they're just white "yellow" springs.
http://www.speedtechrc.com/store/ebp...id=464&id=6203
Turbo Joe is offline
Old 07-05-2007, 12:10 AM
  #7998
Hebiki's Avatar
Trader Rating: 26 (100%+)
the TA05 or the TA05R DOES NOT come with super stiff springs. they are either the all silver kit springs (original TA05 kit) or the white colored with yellow dab springs.
the "kit" silver springs fall inbetween yellow and blue on the tamiya scale. the yellow springs (painted all white with the dab of yellow) are PERFECT for asphalt racing. these are the springs that are always included with tamiya kits. the reason they released all "white" springs with dabs of color on the bottom is to hide a driver's set up from other drivers.
as for the kit shock oil. they are tamiya 400 wt oil. they are very similar to 40wt oil. some have said they are equivalent to associated 30wt. but its tamiya's version of 40wt oil.
Hebiki is offline
Old 07-05-2007, 01:55 AM
  #7999
sosidge's Avatar
I drew up a couple fo build tips here - http://www.sosidge.com/2007/05/09/ta...-r-build-tips/
sosidge is offline
Old 07-05-2007, 07:34 AM
  #8000
macnkitty2002's Avatar
you're kidding right?
thanks for the link. i browsed around some other threads and they are so very helpful. i will keep my computer by my side while building the kit.
thanks for all the help guys, i really appreciate it. my kit comes today, and i can't wait to get started!
macnkitty2002 is offline
Old 07-05-2007, 11:53 AM
  #8001
how the heck are you supposed to tighten the nut that holds the ball diff together? i can't get a needle nose down in there, and i can't get the included X wrench in there either.
also, in step 2, the diagram depicts a part A10 that goes in between the spring and the nut, but i can't find it anywhere. do i forget this part or have i probably overlooked it somewhere obscure?
thanks again
Old 07-05-2007, 12:02 PM
  #8002
haha nevermind i'm a dummy!
Old 07-05-2007, 12:24 PM
  #8003
The diffs were worrying to assemble for me as well, just because it seemed like the main bolt barely got to screw into the nut on the other side. If I tightened it more than like one thread into the bolt,the diff was too tight and didnt spin smoothly...and if it backed out another half turn, it was completely out of the nut.
I havent actually run my car yet, so Im curious if Im going to have issues with the diffs.
Frost99999 is offline
Old 07-05-2007, 01:32 PM
  #8004
sosidge's Avatar
You need to crush the spring with pliers before assembly otherwise it will be almost impossible to assemble, I do mention this in my blog build tips referenced above.
sosidge is offline
Old 07-05-2007, 02:09 PM
  #8005
lbckevin's Avatar
Trader Rating: 107 (99%+)
Check this out....The MS is out....
http://shopping.rcmodel.hk/product_i...71f0e2692468da
lbckevin is offline
Old 07-05-2007, 03:38 PM
  #8006
Crush them like close them completely, or just squeeze them so they are a bit narrower?
My diffs work and are assembled, but like I said, it was hard!
I must have missed that part, I did read some of your blog...Im pretty sure the manual didnt say anything about compressing the springs...seems like something they should mention!
Old 07-05-2007, 03:40 PM
  #8007
He means just compress them a few times with pliers to break them in
DOTMAN is offline
Old 07-05-2007, 06:12 PM
  #8008
Oh ok. Looks like Im popping my diffs apart tonight
Old 07-05-2007, 06:34 PM
  #8009
rctouringracer's Avatar
With all the Tamiya kits I've owned, I have never had to pre-compress a spring to get a diff to work properly. I haved owned several other touring cars from other manufactures and have never had to pre-compress the springs to the those diff either. This discussion about pre-compressing has not convinced me to do so and feel you'll may be misinforming new enthusiasts on proper setup. I think all Tamiya diffs should assembled according to the specific instructions provided!!! Tamiya diffs like other manufacturers diffs need to assembled run then readjusted after the initial run in and then regularly checked as part of your normal inspection and maintance done on the vehicle.
rctouringracer is offline
Old 07-05-2007, 07:03 PM
  #8010
Im actually considering just running it a few times and seeing what happens. I get my radio this weekend, so Ill let you guys know how it goes
