Tamiya TA05 Touring Sedan
#6811
TA05R coming !
What time TA05 TRF
What time TA05 TRF
#6813
Originally Posted by Tainen
reading through the thread, didn't find much of any conclusive info, so I'll post here for more specific talk about this problem:
Running a mostly stock TA05, just has universals up front, and aluminum diff halves up front (kept breaking stuff up there).
I just put on Tamiya B3 tires, medium inserts, new Tamiya porsche carerra body, carbon fiber wing, to get ready for the TCS race this weekend.
Well, when taking right turns, the car either does one of two things:
Really has a hard time turning, takes the turn wide OR
turns really sharp, and spins out. I can sometimes control this by counter-steering the oversteer and getting a half a foot drift and keep going.
I need to solve this by the race, its really hurting my lap times.
When I try to look at tweak by lifting the car up with a hobby knife on both sides, its pretty close. I set my camber to 2 deg in the front, 1 deg in the rear. At first I thought it was some glue on the tire, but all of that is now worn off and its still doing it.
Troy recommended making the rear lateral link longer by bumping it farther out one hole on the diff cover to help solve it. Any other ideas? I don't think I'll be able to practice with the car again on the track until race day, unfortunately, so anything I can check/do at home would be very helpful.
Thanks,
Rick
Thanks,
Rick
Good Luck at The TCS
#6814
Hello to all the TA05 experts, I'm hoping you can help me out with my TA05. I bought one used off of ebay and it had a few hopups on it:
Titanium turnbuckles
Special blue shocks
Center oneway
Front oneway
Blue screws
Blue aluminum hex wheel nuts
I'm planning on running this car at the Tamiya track in Aliso Vejo, and wanted to switch the center oneway back to the default setting, but I don't know what parts I need to get.
I'd like to get some hop ups for this car, but I can't seem to find in the parts at the local hobby stores (ultimate hobbies, speedtech), so what mail order places do you know where I can get upgrade parts for this car? I'd like to get the following items:
Front spool
F/R carbon shock tower
F/R sway bar kit
Racing spring kit
Also, what other upgrades should I consider getting to improve speed/durability?
So far, I like this car; it's seems to have pretty good potential.
Special blue shocks
Center oneway
Front oneway
Blue screws
Front spool
F/R sway bar kit
Racing spring kit
#6815
Thanks,
Rick
Thanks,
Rick
#6816
Thanks,
Rick
Thanks,
Rick
#6817
Regional Moderator
Thanks,
Rick
Thanks,
Rick
If everything checks out, then your next step is to make sure the droop is equal to both sides. The droop dramatically effects this car. And if its slightly off, it really plays games with the steering on the car.
#6819
TWEEEEEEKED???!!!****
To me it sounds like something is tweeked, meaning something might be bent or broken. Check hinge pins inside and out, shock end connectors,anything binding the suspension. I think you said the chassis isn't new! Right? It wouldn't hurt to check the servo saver and the servo itself. You did say you had universals in the front but not in the rear so those stock dogbones could be hanging up slightly, check for unusual signs of wear around the outdrives!
Everything that was said prior to me also is valid information! I guess you have your work cut out for you! Huh!
Hope this helps! Just my 2$
#6820
Special blue shocks
Center oneway
Front oneway
Blue screws
Front spool
F/R sway bar kit
Racing spring kit
Special blue shocks
Center oneway
Front oneway
Blue screws
Front spool
F/R sway bar kit
Racing spring kit
#6823
Regional Moderator
Even though most of us already have our TA05's where we want them hop up wise, there does seem to be a few people left who are still interested in the 05R, but aint no way they're going to pay $360 US for it! Hell, I don't even have that much $$$ into my TA05, and it has a lot more on it than a 05R.
That guy might wanna reconsider that price.
#6824
R/C Tech Elite Member
Good point, for someone wanting to get into the 05, yeah the 05R is a good choice, but for those of us already with an 05, too late! We've hopped it up already! Only hop up I'm missing is the LW Suspension (Asphalt track, harsh turns with limestone walls, it's a durability thing) and the alloy side brace (Now thats just blatent bling!)
