Tamiya TA05 Touring Sedan
#6376
What would be the toe in if i used XC in the front and a in the rear?
#6377
Originally Posted by tamiyarcracer
which side of the thrust bearing is the screw head on? there is a brass piece in the middle of the thrust bearing. there is a square end and a tappered end. Make sure the screwhead is on the tappered end. I've seen a few loosen up cause it is on the wrog side.
OscarF1, I'll try some o-rings. I like the idea of o-rings as the foam plugs got compressed fairly quickly. I take it the voilent hopping isn't a good thing? Perhaps I'll dial back EPA for now.
#6379
Originally Posted by ducati
I'll check and report back. I am not sure, and guess I have a 50/50 chance of being correct . I built (and rebuilt) the diffs looking at the manual, which doesn't seem to make mention of this
#6380
Originally Posted by tc3team
Hey guys, im new to the ta05 and need to hook myself up with a spring tuning set for it- has anyone got part numbers for this or do you have to buy them just in pairs of one colour?
Thanks guys!
Thanks guys!
Hi,
The part number for the spring set is 53440.
A good starting point is yellow rear and blue front.
Regards,
Sarah
#6381
Originally Posted by Saz
Hi,
Regards,
Sarah
Regards,
Sarah
#6382
(every change in letter is 0.5 degree in toe). so....
XC - XB - XA - X - A = equals 2 degrees of rear toe in.
the above explanation is great.. but two small mistakes/typos
A front and A rear = 0 degree toe in
change now to
A front and B rear = 0.5 degree toe in
A front and C rear = 1.0 degree toe in
XA front and A rear = 1.0 degree toe in and slightly narrower track.
change now to
#6383
Thank you waOscar and Hebiki! That is very helpful to us TA05 newb's who don't have Excel on our home computers to read THard's .xls files.
#6384
Hebiki:
Hi,
I need some help in finding the bearings that go in the diffs for my TA-05. seems they are the same size as the ones for my EvO V so being in a rush to run it I took them out of my TA-05 to buld a front diff for my EVO V not knowing they would be hard to find where I live.....
Thanks in advance
Tim
Hi,
Thanks in advance
Tim
#6385
Originally Posted by TimXLB
Hebiki:
Hi,
Thanks in advance
Tim
Hi,
Thanks in advance
Tim
#6386
Originally Posted by DA_cookie_monst
The manuall keeps the diff halves in the same orientation, and you should also be able to work out which is the longer and which is the shorter diff outdrive.
#6388
Hebiki:
Hi,
Thanks in advance
Tim
Hi,
Thanks in advance
Tim
I might have some of those bearings in my bin o' Tamiya parts. I'll check tonight and bring them with me to the track this weekend if I still have them, and hopefully my finished car. Thanks for the setup help this past weekend as well.
Andy
#6389
Originally Posted by Hebiki
assuming you have ZERO degree rear hubs....
overall.. having the standard TA05 original suspension, the rear hubs i believe have 2 degrees of rear toe in. (someone correct me if im wrong, i havent used the old suspension in awhile )
#6390
tao5
hi,
im looking for a setup for my ta05 with a oneway for ashphalt
