Tamiya TA05 Touring Sedan
#5446
Originally Posted by Hebiki
New center shaft means the battery moves CLOSER to the center. looks like the TRF416 to me!
Before u guys get any wild ideas,
There is no other chassis of this type to be produced and it is a 1/12 based chassis designed to fit only the 934 body. According to Tamiya in our meetings with them this car is not and will not be anything similar to the fictious 416.
It is one bling car to keep but race.......that is yet to be seen.
Cheers
#5447
I was thinking, that looks fare bit shorter than my '05....
Not to sure on the way the layshaft mounts, long shaft, one half supported on bearings, the other half sticking out in free air with the spur and pulleys on it...
I want them bulkheads for my '05 though... wonder is someone could make the chassis longer to cater for the '05 belts.... mmm
#5448
I don't think it's 1/12 but it's 1/10 scale. Check the number:
TA05: width 191mm, wheelbase 257mm
Type934: width 202mm, wheelbase 230mm
So it's 11mm wider, 27mm shorter still within 1/10 scale I say.
And if you see it closly, the front/rear bulkhead is NOT what they use on 415MSX/MRE. The MSX/MRE bulkhead (photo) only has one screw to secure 2nd desk, but Type934 (photo) has 2. So at least the bottom part of bulkhead is different. I guess it's big chance it has the same bottom screw location with TA05 bulkhead.
I would say it's 100% TA05 origin TRF416-lead. Now the only question is.. how much it gonna sell on street. (My wallet.... )
#5449
Maybe it's intended for the new 4cell rules in Japan
Just have to mount a decent bodyshell on it......
#5450
maybe it's just a short wheel base chassis!
#5451
The description says that the 934 will have a special reversable suspension arm. Sounds like what happened with the TA-04SS Audi.
#5452
It would be a cryin' shame not to race that baby.
#5453
It's highly doubtful any of these special pieces will fit the tub chassis.. from what it looks like, the suspension shafts are nearly 5mm shorter, as are the bulkheads to accomodate them. The wheelbase is as short as a Mini's..
I sure wouldn't be racing this thing, as a replacement chassis will be scarce..
#5455
#5456
It looks like normal short reversible arms on the pictures....
#5457
#5460
After looking at the Tamiya website photos for the new TA05 Commemorative car, the cantilever design that holds the spur gear and belt pullies, I can't imagine it being stable/durable enough for mod type motors, it looks like it would get wobbley or the bearings would wear quickly or the main shaft might tweak after a while - just doesn't look like a robust design for racing.
That being said, I really like the thought of this kit and I do not think this model is meant for racing duty, but if the new center bulkhead design is carried forward to the next TA05 or 415 chassis designs, I will be sceptical of the design - might have to take a wait and see approach before buying.
