Tamiya TA05 Touring Sedan
#4429
What are common parts to break on the TA05? I'd like to have some spares, and my LHS will stock common parts to break if I let them know what to order... I'm re-learning and hitting the boards at least once a session. Sometimes farily spectacularly
#4430
Originally Posted by ducati
What are common parts to break on the TA05? I'd like to have some spares, and my LHS will stock common parts to break if I let them know what to order... I'm re-learning and hitting the boards at least once a session. Sometimes fairly spectacularly
#4431
Originally Posted by TimXLB
Hi,
any idea when the new Tamiya motor mount for the TA-05 will be out???? also is it ok to run the 48mm CVD's up front with the stock arms???
48mm CVD's should work with the stock suspension blocks and wider, but it'll be too tight if go with narrower blocks
#4432
Originally Posted by Slotmachine
I can honestly say that I have replaced every suspension part on my car...........only because they got old and sloppy. These cars simply just don't break very easily. I did bend 1 hinge pin , I bought the coated ones and have had no more problems...........
#4433
Does anybody here try the new short arm with TA-05?
#4434
just asking if anyone is using the new light weight shaft and any input (i.e any good worth the money)
but i will be getting becasue of the clips you have to get off lol
#4435
What is the best gearing for silver can motors?
#4436
Hi guys,
Just want to post a quick note we have some of the new TA05 hop-ups in stock:
Light Weight center shaft
Aluminum sway bar holder
New short reversible arms
Titanium nitride coated 2.6mm outter suspension shafts
Also, most of the spares and hop-up parts are in stock as well. We will also be putting up an article on the TCS legal TA05 project car, which will be raced in next month's Tamiya TCS regional in the GT-1 class (wish me luck...)
Steve Wang
Steve Wang
#4437
If anyone is looking for hopups and replacement parts I have a ton of new unopened parts for sale. Check out my thread http://www.rctech.net/forum/showthread.php?t=119536
#4438
If anyone is still not sure if they want to get a TA05... well all I can say is you should
So far this car has given me 3 podium finishes (top 3 only) and I'm no full time racer. Never finished in the top 3 with my other EP car. It's so much easier to drive and not much setup changes needed.
Roy
Roy
#4439
need some help guys,
What part number or size of suspension shaft do I need for the lightweight suspension?
what bearing size or part # for the front and rear hubs?
thank you in advance.
#4440
Hub Bearings for the LWS are 5x9mm.
