Tamiya TA05 Touring Sedan
#3691
Originally Posted by KilRuf
Here's my TA05 with carbon tub and TechRacing 18t pulley/belt set.
Where they come from ? Techracing, 3 Racing ?
#3692
Originally Posted by m i g v e a
what is the difference in performance of this blue belt?
#3694
Originally Posted by akuhon
Kilruf, I see your front alum blue upright and also blue motor mount?
Blue motor mount is from Xenon. The dull silver motor mount just looked out of place on a car with all these blue hopups. So I opted for the Xenon unit. I know SpeedtechRC carriers Xenon and Square.
As for the belt, I have not tried the original belt with this 18t pulley. And only 2 teeth does make a difference in size too. The new white belts.. I have them about 2 clicks loose and they are not slack. So I would think the original belt size would not have enough adjustment to fit..... If you want a blue belt... get a blue marker!! haha..
#3695
Originally Posted by cannon
Car looks OK but the batteries look fantastic
#3696
Originally Posted by danjoy25
Got new pics of my car now with stabilizer and th carbon upper deck thingy.
#3697
Originally Posted by rayman
Where did you get those blue screws and turnbuckles. My swaybars are also not colored. They're plain steel
#3698
just wanted to post some pix of my TA05, I have never tried to run the car with the CF parts yet, matbe next month when I go and try to visit Fredericks, MD.
#3699
Thanks. I'll check out the LHS for the blue parts number. Maybe they have a purple version.
#3700
I run the Square EvoIV blue steering knuckles or uprights.. or whatever you want to call them.. They are more durable for me. Especially when I occasionally race carpet/foam. I save the plastic knuckles for TCS races...
I think I have to have 2 TA05s then.... hahaha. One will use tamiya only option and the other will use any 3rd party aftermarket option.
I'll re-think of getting the square's front upright ... but rear one is okay... since I plan to use those alums susp. mounts.
About the belt, you're right.... how about spray it with metallic blue (j/k)
Thanks, you've been so helpful to me
#3701
#3703
Originally Posted by Viat
It is my first TA-05. What you guys think of puting futaba 3003 servo? I plan to race in TCS GT-2 races.
As for servo, save some money for a better one. I recommend the low profile one such FUT-9550 or new KO 'cause the space is kinda limited for this chassis (if you're after low CG).
#3704
Regional Moderator
Don't worry about low profile servos, theres more than enough room on the chassis for electronics. I have a full sized KO servo on mine with a Novak Xxtra reciever, all mounted low profile on the chassis. Every thing fits easily.
#3705
What do you think Darkseid, about
"Futaba 2PL 2-Channel AM/1 S3003/MC230CR ESC"
http://www2.towerhobbies.com/cgi-bin...I=LXENN1**&P=7
I mean everything that is included?
