Tamiya TA05 Touring Sedan
#3316
Regional Moderator
Originally Posted by POOKYT
Does this mean some of the newly released carbon tub chassis's are not flat?
Brant
Brant
I didn't noticed any on mine when I put it on my glass setup board prior to assembling, but there seems to have been some issues with some chassis.
#3317
A gearing question:
I'm assembling my TA05 this week and have already purchased a 104t 64p spur.
I'll be running 58mm trued foams on Ozite in stock with an Epic Binary motor.
The track is 80'x44' and is generally technical.
What pinion range would you guys suggest?
#3318
Originally Posted by Batfish
A gearing question:
sorry wrong reply.....
#3319
Originally Posted by akuhon
Thanks Jack2, you're right it's really tight side to side... I can manage it but just affraid if someone bump me on the side, my rcvr box will crack....
Thx for the info, I plan to change with FUT 9550 servo since it's shorter than std. Hope I have more space for the rcvr.
Also, I see there are not many option for spur... before it comes out of the bottom spur hole on the lower deck... What the max. spur for either 48P or 64P ?
#3322
Originally Posted by dodo
9550 is the right choice for this car, it will give you a lot more space for your rx311, i used that before i switched to KO
-O
#3323
Ohh yeah... nice turnbuckles...
Fred may I see you electronic layout on the chassis. My receiver seems too big to fit on the chassis, unless I put it on top of the servo. Sanwa RX-311.
Thx for the pics.
Thx for the pics.
#3324
Originally Posted by blindjudge
The TA04 used to have that up front but i decided to take it out because my car seemed to have wandered at times (maybe there was a bind beacuse of those rods) . So what is the purpose of that C_O jones? seems interesting.
Fred
#3325
A gearing question:
If the binary is the RPM version then you will want to gear in between 7.0-8.0 final ratio. Which would be 29 to 34 pinions.
#3326
Originally Posted by OSherman
I hear that KO is supposed to be releasing a servo similar in size as the s9550, but with higher output (faster/more torque)..
-O
-O
i think i got lucky. my carbon tub is only tweaked .5mm
ill fix it with droop, and other settings. anyone run on rubber/asphalt yet? any impressions? (izzy? )
#3328
Originally Posted by eeyan
Izzy's impression ===> (but then that darn pinion coming loose is to blame)
Ian's impression ===> (still using the plastic one)
But I'll still get the new chassis... soon! It is stiff...
One thing I like was the Battery tape slot on the new chassis. That was it.
#3329
Anybody knows what compound or type are rubbers that came with the kit? I got the Supra Esso, not sure if it's the same for earlier batch.
Thanks.
Thanks.
