Tamiya TA05 Touring Sedan
#2536
Best thing to do is invest in some Alloy rear uprights which have the flat 3 position camber link holes. That way you can change the length of your camber link without adjusting the height and you can also make small adjustements to the height of the link also. I make small adjustments to the height of thecamber link which changes roll centre, to gain and loose grip. Its amazing how much feed back the car has with this change. I havent changed my springs etc for a while now, i adjust the height of the outside rear link and the height of the front inside link. Works a treat
I usually have about 2mm spacer under the linkage (pic doesnt show the spacer tho)
#2538
Originally Posted by SpeedTech
Hi Guys,
Here's a few pictures for our Project XR05. Should have the first article up by the end of the week.
Steve Wang
Steve Wang
#2541
#2542
spring rates
hi guys,
any idea what the spring rates of tamiya springs are?
#2543
steve,
What kind of Turnbuckles is shown on your picture? I'm looking for one.
#2544
Originally Posted by GCT69
steve,
they are Xenon Racing aluminum turnbuckles they have ones that matches the Tamiya blue
Steve Wang
#2546
Spur gear size to use???
Hi everyone,
What's the biggest 64-pitch or 48-pitch spurs can I use with the TA05?? Like everybody, I don't want to get stuck with the overly priced OEM spurs and pinions .
Thanks.
Thanks.
#2548
How about in the 48-pitch size?? Got a few of the 48pitch pinions so hopefully I can re-use them
Thanks.
Thanks.
Originally Posted by Darkseid
108t is the largest 64pitch spur the car will take safely. Anything larger and your looking at being below the chassis line.
