Tamiya TA05 Touring Sedan
#1936
Tamiya TA-05 Picture
Hebiki can you post a picture of your TA-05 up.
Thanks;
Andre
Thanks;
Andre
#1938
Originally Posted by Hebiki
it fits.. if thats what your asking. not sure how well it'll work exactly. anyone have a spare set. ill try it out on mine!
#1939
This maybe a dumb question but, is it possible to make the TA05 into a rally car?
#1941
Just got my ta05. I just got past putting the diffs and center pulley in. With everything bolted, I stuck the dogbones in to spin the drivetrain to see how smooth everything felt. I noticed that the belts move left to right between the pulleys, and occasionally rub and make a sound. Is this normal? It's my first belt drive car, and i don't know what to expect. Thanks for any help.
#1942
Key500/andre - dont have a digital camera with me. what'd you need to look at?
#1943
hey there... looks like your using the stock belts that came with the car. if you use the aramid (hop-up) belts.. when you spin the drivetrain.. you'll notice it stays in place.
Tamiya Sat. what's the gear ratio for a stock motor? Right now I just have what came with the kit. And can you tell me what's a good gear ratio for 19 turn.
I just hope it doesn't rain sat. I haven't had a chance to run my car yet..
Thanks;
Andre
#1946
Originally Posted by DA_cookie_monst
45wt front, 40 wt rear, 2 hole pistons on TRF dampers.
Shocks in kit positions on the front, kit lower on rear, one hole further out than kit on the rear tower. Yellow springs all round.
Red Roll Bars
1' camber all round
0' toe on front
5mm ride height on the front
5.5mm ride height on the rear
small amount of droop on the front slightly more on the rear (increase if back end drifts).
G6 Protoform shell.
If you can, mount the tyres on Inch-Up rims with firm inserts.
Red Roll Bars
1' camber all round
0' toe on front
G6 Protoform shell.
Remember that setup is only a guidline and will need to be tailored to each person's driving style, track conditions and class entered in.
Good luck everyone...
