Tamiya TA05 Touring Sedan
#1846
Alright.. There's a race with Stock Foam on CRC Ozite coming up, with pretty rounded, flowing turns, 92x48' track. I have a few Q's for my TA05...
I have hard blue on-road springs all around. Should I even go stiffer? How stiff should I have the sway bars?
I have center and front one ways, and I know ball diffs are the way to go, but should I leave the center one-way in? I have a precision diff in the front.
What kind of gearing am I looking at for a putnam-brushed monster stock?
I've never run foams on electric touring before (had to put a LOT of spacers to make them free, with only 26mm/28mm width on fronts/rears) so what kind of camber and toe should I be using? I have the stock 2-deg rear toe-in uprights.
Will setup be much different with a 19T Dynasty?
Thanks for any input,
James
James
#1847
Jam-ehz-ahh-fianlly SOmething Tamiya related I can answer.
Try 60/40 oil with small hole pistons. Start with a 33 lb front and a 28 lb rear spring. 1.5 uptravel in front and 2.5 in back. NO sway bars at first. I wold start without the center one-way and put it in if you need it. TIres-try Parma Cyan fronts cut to 2.30" MAX (2.25" better) and Magenta rears. Set camber at 1 de front and 2 deg rear then set so tires wear flat. Ride height should be 4.5mm. Rear toe in shold be about 1.5 to 2 degrees. And try and run 28mm width tires front to back. Narrow fronts lead to rollovers in turns and edgy handling.
Rolll out the Monster at 1.02" inches for a 90+ straight. Dependigng how fast the infield is will tell you if you want to go up one tooth or down one tooth.
#1848
Ray you beat me to it. Jamie go with everything Ray just mentioned, its pretty much as i ran mine last night at practice. Only difference, i loved it after i added a heavy front sway bar. Our track is a little tight also, so on a flowing track like ill be at this weekend, you could try a lighter bar also. Im running front ball diff, centre one way, alloy rear hubs which i assume are 2 deg as thats what it reads on the setup station. Long links, no spacers in rear, and ill also be trying 1mm more than the original setup on the front links. This will reduce steering somewhat, which will be better for the oneway under breaks, also better for a flowing track. The rest is as per the previous post.
Ray have you tried adjusting the wheelbase? Mine is stock with a spacer on each side of the arms, but was contemplating increasing the wheelbase for more stability on the flowing turns. Im doing just that to my 415, as all the guns have suggested that.
I also ran it on purple double purple 28mm jacos, which handled great even without sauce. Ill be running jaco double pink/orange, double pink this weekend. Ill get up some more pics of my 05 soon. My 415 came with a stack of spare blue parts which are slowly finding there way onto the 05
#1849
what I'm using-
Monster stock pro
93/28 --64 pitch with installed fan and heat sink
dbl pink orange and dbl pink tires--front and rear respectively
my tires diameter was 59
need input guys
#1850
Originally Posted by MDawson
Selling off the remaining of my Tamiya stuff.
Here is my latest project, TA05.
http://www.fictionlab.com/mdreel/Daw...roject2005.wmv
PM me or look at the listing in Sell Thread http://www.rctech.net/forum/showthre...28#post1906528
Thanks.
Thanks.
#1851
Originally Posted by cheehtae
what does it mean? I also run carpet and my gearing is 93/28 which makes my motor too hot, i'm going to go down 1 tooth this weekend, BTW when I ued a 93/30 there was no punch coming out of the corner that's the reason why I went down to two teeth which is still fast and has power coming out of the turns, and they are 64 pitches-
what I'm using-
Monster stock pro
need input guys
what I'm using-
Monster stock pro
need input guys
#1852
Here comes my total n00b-in-aweness comment:
Holy crap!! How the hell do you determine all that from the description listed?? Mind you, I wouldn't even be able to arrive at all these settings with the car in front of me, let alone by simply 'conceptualizing' the situation!
Impressive... Most impressive...
#1853
#1854
Great input, thanks. Now, what are the equivalent weights for Tamiya springs? I don't think they quite advertise what they really are..
Now, as if you didn't answer enough of my questions , how would this change with a 19T Dynasty, or is this setup good for all speeds?
Thanks a bunch,
James
Thanks a bunch,
James
#1855
Stock and 19 shouldnt be too different. if you were going to mod, then you would probably need more steering. If you find you need more steering, take out some of the spacers on the inside of the camber link, making it lower. i didnt like this change in stock, gave the car way too much steering for my liking. Send an email to me at [email protected] and ill send you a excel sheet with diff manufacturers spring loads, got it from a guy on the 415 thread.
#1856
oh and on a side note, has anyone seen how the older black plastic ring preload adjusters on the gun metal trf shocks are skinnier than the new blue preload adjusters? I think this might be the source of my ride height problems. my blue adjusters are to the top and i still have 5mm of ride height! might be able to gain about 1-2mm if i change it to the black plastic.... but thats taking off some of its bling!
#1860
Shorter Tamiya springs!
