WRC Racing STX EP touring car
#181
#182
hi all, sorry but I haven't time to try 2.5 chassis, probably next time
#183
Stefano, I'm having trouble with the steering slider getting bound up with dirt and tire dust. How do you keep your steering from binding up ?
Thanks.
Thanks.
#184
clean with tire cleaner, compressed air and use little bit bearings oil, my steering is always clean, use only air for clean
#185
I think we will have some problems with that steering system... With the most flexible chassis, the torsion bind the steering... this system is not viable as it is, we need something monobloc... I've tried to mount the 1.5° part instead of the 0°, the direction only works on the left...
We will obviously need clean steering parts, but we also need to rethink the steering mounts...
#186
not really ... When I first saw the steering system I thought the same as you but after running it there's no such problem. The pins have some 'float' side to side and there is no binding what so ever in flex. The binding I get is from dirt and tire dust on the pins as the block slides over the pins. So far I'm quite happy with the car on asphalt. I may change my mine when I hit the carpet.
I don't understand what your saying about the Ackerman blocks.
#187
#188
I do have this slop, no problem with the 0° part. But I got the 1.5° part, and it cannot move freely on the steel pins... you can move the steering on the right, but it cannot move to the left, as the part was wrongly machined...
This steering works for me too, as I'm not running in very high grip conditions... We'll see...
#189
this car running very well on low/medium grip conditions, high grip need to use 2.5mm chassis
#190
news from wrc,
there will be some improvements with a special update kit expected for mid november
stay tuned
stay tuned
#191
Indeed, great updates from all the factory drivers... You will love the new T ;-)
#192
Mine is hanging on the wall. The issue I have with the steering is apparently only happening too me ...
I'm interested to see the improvements.
#193
last week we ran a 12h lasting race on dirty asphalt (the track is near an off road one and there was some wind)
every time we change the batteries (30 min) we spray a little bit of cleaner on the steering block and pins
we had no problem with the steering, we took second place first place by wrc too
our car was running with 2,25 chassis
#194
That's strange... I've used mine for all the summer races and trainings... about 50 packs in total... And the only thing i've done is to clean the steering with the air compressor and check that the small axle supports have not moved... They can rotate a little bit and bend the steering... I've seen no other problem...
#195
We've spraied cleaner only to avoid the block of steering, during a 12h race it could be have happened
