Like Tree246Likes
Xray XB4 thread
Old 01-16-2018, 01:00 AM
  #12706
Trader Rating: 43 (100%+)
Originally Posted by snwchris
Low Bite dirt I've been using 300k or 500k
1mil is usually for high bite tracks if remember correctly.
from Bent Karlsen:
Heres a ‘17 with graphite arms, uprights, c-hubs and steering knuckles, medium chassis braces and chassis sides, center diff with 1 million cst and all composite gears and pins for all the diffs for increased traction 👍 Awesome on medium grip dirt 😃
https://www.youtube.com/watch?v=eJcB...ature=youtu.be
Phillip F is offline
Old 01-16-2018, 01:36 AM
  #12707
Anyone tried the 2.5mm chassis out yet? Any thoughts?
Also i havent been overwhelmed by the out of the box suspension when compared to my other cars. Any upgrades or tweaks recommended? The long kashima's were a great upgrade on the ae - does xray have anything similar?
Maraach is offline
Old 01-17-2018, 09:28 AM
  #12708
Trader Rating: 33 (100%+)
i have seen the new 2.5 chassis.. looks nice.. the guy using it.. said it was good.. i personally think the stock chassis will be fine.. so you can adjust flex with the braces..
not certain what you mean out of the box suspension.. kashima coated shocks from AE.. basically is a hard coated shock.. but.. with a fancy name on it..
i will say the machined pistons are nice.. wish Xray would go to the machined pistons away from tree pistons..
other than that.. the updated lower bushings help in life of the shock.. as well as smoothness.. very easy to build.. and mine stay smooth for very long time..
dgrobe2112 is offline
Old 01-17-2018, 09:58 PM
  #12709
Apologies i should have been more specific.when i went to the kashima shocks i also replaced all internals with the machined parts. That combined with longer rear shock body mnade a noticable difference to the smoothness of the shock. I was hoping xray had a similar 'upgrade'
Maraach is offline
Old 01-17-2018, 10:53 PM
  #12710
I understand. No. No upgrade option. The only thing I wish we had was machine pistons. We do have longer shock ends for more droop.. but that's about it. Our shock shafts are same length as AE btw. In front and rear.
If you wanted you could try the AE on the car. See if you notice an improvement in performance. I tried AE pistons. But didn't don't think they fit correctly in the shock bodies. Car didn't work as good. But that was only a piston and shaft change..
Old 01-18-2018, 05:40 AM
  #12711
snwchris's Avatar
The Xray shock feel great only change I did to mine was buying the Avid machined pistons for them.
snwchris is offline
Old 01-18-2018, 06:21 AM
  #12712
If only they were still available
Old 01-18-2018, 06:53 AM
  #12713
VRP makes machined pistons
windycityblues is offline
Old 01-18-2018, 09:37 AM
  #12714
snwchris's Avatar
Schelle is another option for Pistons as well
snwchris is offline
Old 01-21-2018, 04:03 PM
  #12715
What AE shock shafts did you use? I dislike e clips and would like to use the AE V2 shafts if u can.
avink007 is offline
Old 01-21-2018, 04:23 PM
  #12716
AE shafts are same length as xray shafts. U can use the threaded if you want. I used the eclip ones. This was when I ran the 16... I don't use them anymore
Old 01-21-2018, 04:32 PM
  #12717
Did you use the B64 shafts or something else?
avink007 is offline
Old 01-21-2018, 08:32 PM
  #12718
Pville Stig's Avatar
I tried the AE shafts as well and didnt like the side to side movement with them. They may not be the same diameter, Never checked and went back to xray.
Pville Stig is offline
Old 01-22-2018, 11:23 AM
  #12719
What's a good starting gearing for a 13.5 motor on turf? Searched but couldn't find any info
roysays is offline
Old 01-22-2018, 11:31 AM
  #12720
symmetricon's Avatar
Trader Rating: 27 (100%+)
25/75 approximately depending on motor and timing.
symmetricon is offline
