Like Tree246Likes
Xray XB4 thread
Old 12-13-2015, 05:58 PM
  #9601
Trader Rating: 11 (100%+)
Does any know how wide the 4 stripe 12mm hexes are?
sealander is offline
Old 12-13-2015, 07:07 PM
  #9602
Trader Rating: 36 (100%+)
Originally Posted by mconway
I am just ordering my firs Xray XB4. I have tried to search but can not find the exact answer. I want to run 12mm from my lost 22-4. I searched Xray info and Exotek but still not sure which I need to order. Anyone have exact answer to this? Thank you
http://www.amainhobbies.com/rc-cars-...409blk/p441104
http://www.amainhobbies.com/rc-cars-...410blk/p441105
You need this if you run losi wheels. Just order last week same offset front/rear 247mm
raved007 is offline
Old 12-13-2015, 07:12 PM
  #9603
kuruption's Avatar
Trader Rating: 24 (100%+)
Originally Posted by sealander
My xb4's front end comes up when I blip the throttle, do I calm that down by changing the front or rear kick? I'm running the book setup.
Change front droop... i.e. more spacers on the shock shaft inside of the front shocks.
kuruption is offline
Old 12-13-2015, 08:18 PM
  #9604
Trader Rating: 118 (100%+)
I run on very high bite rubber/foam track. I'm in need of stiffer front springs than the Xray 4-dot.
What other springs fit the XB4?
Chris Furman is offline
Old 12-13-2015, 08:23 PM
  #9605
suby723's Avatar
Trader Rating: 21 (100%+)
All big bore springs fit. Try yokomo yatabe springs or ae springs. Also have you installed 12 degree caster blocks yet?
suby723 is offline
Old 12-13-2015, 11:17 PM
  #9606
Trader Rating: 15 (100%+)
probably answered in here somewhere, but what would it take to run the newer gear center diff instead of the slipper setup in my '14?
fivepointnine is offline
Old 12-14-2015, 05:32 AM
  #9607
Yes, been running 12* since day one.
Thanks for the info.
Old 12-14-2015, 05:42 AM
  #9608
Xray 4-dot C=.080 equals 4.58 lbs
AE hardest spring is Purple at 4.2 lbs
Haven't found a chart yet for Yokomo springs.
Old 12-14-2015, 06:03 AM
  #9609
WillS's Avatar
Trader Rating: 32 (100%+)
You will have to convert the weights...
WillS is offline
Old 12-14-2015, 06:40 AM
  #9610
A lot of work, some drilling, cutting & shutting & possibly some different length drive shafts.
Easier to pick up a used '15 car.
John Myall is offline
Old 12-14-2015, 08:34 AM
  #9611
gticlay's Avatar
Trader Rating: 14 (100%+)
I went through the Petit Big Bore Spring chart and wrote in the X-ray springs for my reference. The 4 dot rear is ever so slightly softer than the Yatabe Arena Black and somewhat firmer than the Durango Dark Red and Yatabe Orange. You'll see what I mean if you look at the chart.
gticlay is offline
Old 12-15-2015, 06:28 AM
  #9612
Default XB4 12 degree caster blocks
Just bought a 2016 coming from a HB D413. I understand the 12 degree aluminum caster blocks is a must for astro setups. Can't find them anywhere except for amain.
Where do I find these?
Till they are back in stock what can I expect from the stock caster on high grip? Is it really that twitchy?
Vincent_Diesel is offline
Old 12-15-2015, 06:45 AM
  #9613
suby723's Avatar
Absolutehobbyz superior and discountrc and your best place is Rc America(call them)
suby723 is offline
Old 12-15-2015, 06:53 AM
  #9614
kuruption's Avatar
I picked up a pair from Absolute yesterday... believe they still have them in stock.
Old 12-15-2015, 06:58 AM
  #9615
symmetricon's Avatar
Trader Rating: 27 (100%+)
I bought the 12deg casters but found i like the car with out them. I have an awesome setup for high bite clay...
symmetricon is offline
