Xray XB4 thread
#9316
#9318
#9319
There's nothing "going on" with spare parts.
They have been readily available since the release of the kit.
When lists where sent out with part numbers for the new kit and spare/option parts every distributor could order as many as they wanted.
First come first serve.
However with the indoor season starting up now I know people have been stocking up on parts.
And with arms, bulkheads and towers being new and updated I know a lot of people have bought parts to upgrade their '15 XB4's as well.
So even here in Europe where stock have been good there has been a real challenge to keep parts in stock.
But production is going full speed so there should be no reason for concern
We're heading to the factory on Wednesday for another race there and can't wait to take another tour of the factory to see the new machines they've acquired since our last visit
Bent
Bent
#9321
Which bodies can I run on the '14? does it have to be '14 specific or will the '15 and '16 also fit? And are the wing mounts all the same? Wasn't sure if they changed. Thanks.
Also if it's not too much trouble, maybe you could tell me which parts I can use from the '15 on the '14 (arms, towers, etc...)
#9322
is the 16 bevel and pinion improved ? is the bulkhead reinforced on top where they break off on hard landings, even if a small carbon U brace was made for the front,would be a big help
#9323
I think most of the differences between the '14 & '15 cars were on the chassis, so that would be many bits to change. Arms and towers are the same I think. You could use the metal diff gears from the '15.
#9324
You will need the '16 shock towers, or to modify the ones you have to clear the extra bracing bits.
#9325
I don't know anything about changes to the gears, but the bulkheads have extra bracing on them to help stop them breaking at the top, plus extra material inside to help with gear life/bearing fit.
Material have been added to the area where the diff bearings sit in the bulkhead.
Other than that…..read below
Here's the '15 and '16 bulkhead side by side…….
Bent
Here in Europe we run on high grip astro and carpet all the time……..with no issues at all during an entire season of racing at the highest level with boosted 4.5T motor.
People need to:
Just one of these things will affect gear life…….then add up several of them and you WILL have problems !
Material have been added by Xray to where the bearings sit in the bulkhead and to the bevel gear to prevent the gear mesh to be affected by the above points, BUT there is a limit to what you can do before the responsibility has to be on the end user to actually make sure everything is done correctly.
These cars are race vehicles and DO require some knowledge from the end user to perform at their best.
Follow these tips and you will have zero problems with gears wearing out prematurely
Enjoy your upgrade from the B44.3
Bent
People need to:
- Stop over-tightening screws for the diff housing (allows the diff housing/bevel gear to expand and affect gear mesh).
- Stop overfilling their diffs (allows the diff housing/bevel gear to expand and affect gear mesh).
- Stop over-tightening screws for the bulkhead cover using electric screw drivers (allows the diff bulkhead cover to expand and affect gear mesh).
- Replace worn out bulkhead.
- Replace both pinion and bevel gear if already stripped one of the gears.
- Replace shot bearings.
- Stop cranking their slipper down way too hard and instead set their slipper according to grip level (we run 0mm on the spring/loosest setting).
- Stop using the 1/8th buggy method of cranking the throttle to get the car back on its wheels.
Bent
#9326
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
How has this new car running on USA style clay tracks?
#9327
I think the new '16 only been available in the U.S for a week or 2 now……
Tyler Vik is running the XB4 but I haven't kept up on his racing lately.
So far the Xb4 has been awesome on clay for us……..
Bent
+ YouTube Video | |
Bent
#9328
Super good. I ran mine on a day when our track was lower bite and it was super stable and easy to drive. Another day our track was back to normal with tons of traction and the car came to life, tons of steering and corner speed.
I've been trying different adjustments every time I'm at the track but it was really good even just out of the box. The changes are now to dial the car in for my driving style and track conditions. It's also really awesome how sensitive the car is to adjustments. I know on my B5m I can change things and not really feel much difference. On the XB4, everything is a more noticeable change.
#9330
Rule of thumb; moving hinge pins out or up gives less roll. Moving them inside or down gives more roll.
Increasing track width takes away grip/steering and decreasing adds grip/steering.
Bent
