Xray XB4 thread
#8656
Thanks man!
here is my set up that day,and yes i was using 8000 centre diff fluid.I built the kit
with 100,000 then tried 50,000 then 20,000 then 8000 the lower i went the faster
i was getting around the track and the easier it was to drive and more off power steering i had on our slick track,3 other xb4s went down to 15,000 in the centre diff from 100,000 and all much preferred it.
#8658
#8659
What is needed to run the center gear dif on the 2014 model?..
#8660
Front: 1,5-1,1
Rear: 1,6-1,1
That is what you could start with when it comes to oil weights (See info under), but personal preference is key anyway.
Just got mine today and are going to mount them and race the buggy this weekend. New build so I am pretty excited as this is my first 1/10 buggy, ever... Only run 1/8 scales up to this
From Avid's web store:
Rear: 1,6-1,1
#8661
Cool to hear that you have improvements tho
37.5 as Losi WT will be approx: 450 cSt and 37.5 as Associated WT will be approx: 500cSt if this info is used:
Code:
Unofficial conversion values provided by Gene Hickerson USA cSt Losi WT Associated WT 100 10 7.5 150 15 12.5 200 20 17.5 275 25 22.5 300 27.5 25 350 30 27.5 400 32.5 30 425 35 32.5 450 37.5 35 500 40 37.5
For my self I have a 100% build buggy and no chassis, as both chassis plates, incl. the one I got as replacement was slightly bent. Xray wanted me to send both to them for an investigation, and they will send me a couple new and guarantied straight as an arrow. Hopefully it will be less then two weeks or less. Can't wait to get my buggy up and running!
#8662
I have purchased the ball diffs. Do I need a different bevel gear (2015 model).
#8664
I have xray 365000 diffs and they don't fit. To big. Are those the wrong diffs.
#8666
#8667
#8669
So I'm trying to setup my xb4 4wd for my local clay track and I am trying to see what oils I should start with for the shocks and what oils for the dif. I'm running a 2014 xb4 I bought used mad trine to go threw it and get it set to hook at my track. Any suggestions would be great.
Thank you
Justin
Thank you
Justin
#8670
Thank you
Justin
Thank you
Justin
Look on RCAmerica under downloads, there are some good baseline setups there.
