Xray XB4 thread
#7741
I think ill start with a 19 after hearing what you guys have to say. Im running on a offroad indoor carpet track. Tight turns.( most are 90 degree and 180 degree turns. With about a 50 Foot back straight id say. .
#7743
Anyone notice the carbon fiber underneath the front and rear top shafts?
#7744
Yeah I see it. I wonder if that was done to stiffen up the chassis enough to run without top decks. Possibly a temporary solution until 3mm chassis was realeased? Not positive as I am just taking a guess as I don't see the X-brace and the chassis looks to be the standard 2mm. If so this would be more economical on the wallet than purchasing the new 3mm chassis. Easy as well for one to fabricate I would think.
#7745
Anyone receive their Rear Rear replacement hanger? Another question: has anyone had any issue with the rear front hanger being off? Thought I would inquire as the rear front hanger looks to be fine.
Best,
N
Best,
N
#7747
I really not positive wether it's the 2mm chassis or not. I think it is likely the 2mm chassis, as I would think the 3mm chassis would not need added rigidity through the use of adding CF stiffiners in conjunction with the composite multifflex chassis braces.
If it is the 3mm chassis I believe that any extra rigidity needed would be through the use of the CF X brace(front top plate). Seeing the pic which does not show the Xbrace but shows the added CF chassis stifffiners makes me think the 3mm chassis and X brace were not yet produced.
However I could be totally wrong.
Best,
#7748
It does not look like the chassis has the milled out areas by the slippers rear bulkhead which you can see on the 3mm chassis. If this is the 2mm chassis I like the idea of the incorporating CF stiffiners with the composite M Flex chassis braces as a cheaper alternative to purchasing the 3mm chassis. If it works well it makes running without top decks a quick option.
#7750
#7751
HeavyD,
Best,
Best,
Running without the front X-brace gives a bit more steering as well
Bent
#7752
If you don't mind, can you provide the part # for the optional stiffer side pods?
As always much appreciated for sharing your knowledge and experience, as it is always very helpful.
Thanks again and have an excellent weekend
#7753
Thank you Bentka for the clarification my friend. I was not aware of there being optional stiffer side pods. With there being optional stiffer side pods that makes total sense in addition to the added CF center brace stiffiners. This is a really cool tuning option as it is efficient both time wise and $wise. Are the center CF stiffiners modified CF top deck parts?
As always much appreciated for sharing your knowledge and experience, as it is always very helpful. ��
Sorry but theres' no part numbers for these parts yet.
And thanks
Bent
#7754
It's very nice to have Bent back on the forum!
#7755
