Xray XB4 thread
#6601
/ \, these are the toed in rear wheels from top, joined up, the point should be center, its never gonna be.
#6603
No its still an issue because if you join the imaginary lines where the rear wheels point to, the point is not on the centerline of the chassis. So all things being squared up, the car will not track straight (with zero front toe, front wheels parallel to chassis centerline).
#6604
Nah not total, if you got 3 degrees from chassis center on each wheel only then it will track straight. The hudy can only measure the sum of total toe (then we assume its symmetric on both wheels), it cannot individually measure the toe (w.r.t. center) at each wheel like a real car alignment shop.
So here people got say 2.5 left side and 3.5 right, the car will tend to pull left always.
#6605
#6606
Imagine that you were able to rotate the rear gear box a quarter of a turn, 90 degrees horizontally on the chassis and mount it that way. The rear wheel pair will point completely sideways to the normal direction of travel. Now imagine you would be able to put the setup station on this. It will give you measurements in degrees for your rear wheels that are the same as when you had it mounted the correct way. The setup station measures against the common centerline of the wheels but has no way of telling you that that center line is not aligned with the center line of the vehicle, in this case as much as 90 degrees off, but just looking at the setup station it will give you the same number.
Hope this helps...
For the record, a setup station is a great tool, not knocking that. I use it frequently, but as with all tools there are some things it doesn't apply to.
#6607
I will try to describe the point aloksatoor is trying to make in a different way by making an extreme example:
Hope this helps...
For the record, a setup station is a great tool, not knocking that I use it frequently, but as with all tools there are some things it doesn't apply to.
Hope this helps...
#6609
so with all that said, is it right or wrong. Because with xray saying there is no issue I will call amain and get a full refund on my car. ive spent way to much money for amain to say no if xray wont stepup and fix the issue. shtt they wont even admit there is a issue it seems like... sorry to ask such a dump question but with all this technical talk i got lost on if it is suppose to be like it is or is the molds wrong..
#6610
#6611
So the rear end is 0.25mm off the centerline.
I still have no answer for Kevin’s issue and I can’t even replicate it on my car. It’s either a manufacturing issue with Kevin’s kit or Kevin’s build skills (which it doesn’t sound like it, with his past experience in building cars).
What’s confusing is that some are saying that there toe-in is out, left to right. Then that’s a problem. I don’t feel that this 0.25mm of center is a real big issue if the toe-in is equal on both sides. Unless someone is willing to do the calculation and tell us that the rear bulkhead doesn’t sit straight on the chassis either.
Has anyone measured from the centerline to the wheel hub? One arm could be longer then the other??? Just like us humans. lol
#6612
Some of these theories are really grasping at straws trying to say Xray is right IMO. Should a car of this caliber be built and designed with a gearbox that sits crooked, or off center, and all other parts are different measurements on each side to compensate? Wouldn't the front brace not be symmetrical either? If the arms were different would it have a left and right dogbone of different lengths as well, if the angles were made up with hub angle wouldn't we have a left and right hub? The only reason we have a left and right arm is because of the sweep and the gullwing design, it would make absolutely no sense to complicate things by needlessly designing the car to require different length arms.
What I'm seeing is that everything IS on center, but the rear brace has the insert farther out on the right(or perhaps the left is not far enough). Take any one of your cars and mismatch the rear inserts, that's what we have when we use all the same inserts. Maybe the new gearbox doesn't require the asymmetrical brace anymore but it got lost in translation, I don't know, but what I have is definitely not right, and I don't mean overly picky spitting hairs not right, I mean painfully obvious something is wrong here not right.
#6613
There is at least one team driver in the midst of getting measurements and looking into the issue. He was told from Xray the same thing posted here earlier but he still wants to confirm that. He already contacted me, I'll let him chime in with his findings If he would like later, one thing everyone has to realize a fix isn't gonna happen overnight.
#6614
I can say that 3.5 toe with a shorty pack works extremely well on a clay track. I'm just going to leave my car with 3.5 toe until there is a fix. Also tried 500k in the center diff up from 100k. It may not be for everybody but you can drive the car a lot more agresive with 500k.
#6615
I took all the shocks off and trace the chassis and the rear suspension arms on the paper. The off set blocks (.5 sideway & 0) give even toe on both sides.
