Like Tree246Likes
Xray XB4 thread
Old 06-24-2014, 10:23 PM
  #4996
joeymdz's Avatar
Trader Rating: 13 (100%+)
Only issue I have ever came across was the grub screw for the rear hub pins being too tight and that will bind up the axle.
Sounds like you all ready found your issue. Either get rid of the flawed narrow hexes or run the stock ones.
joeymdz is offline
Old 06-25-2014, 07:09 AM
  #4997
Good afternoon everyone, my name is Andrea and I come from Italy.
I wanted to kindly ask if and what kind of heatsink / fan I could mount on my xB4
Thank you all (sorry for my english)
Andrea
Corde89 is offline
Old 06-25-2014, 08:02 AM
  #4998
suzukipro's Avatar
Trader Rating: 33 (100%+)
I guess it is possible something is flawed with my set, but would be surprised they would be offered by XRAY as an option part if the fit and finish wasn't up to spec...
suzukipro is offline
Old 06-25-2014, 09:10 AM
  #4999
joeymdz's Avatar
I have a set of the .75's and zero issues with mine. Slovakians can make mistakes
joeymdz is offline
Old 06-25-2014, 07:11 PM
  #5000
fullout's Avatar
Andrea
I would recommend glueing a small fan just in front of the motor. The heatsink/fans usually just clip over the motor, and 4wd racing can get rough, lol. Most likely that heatsink will fall off the motor, this is what i have found in my experiences. Always had better luck with a glued fan. Shoe goo works great and can be removed easily.
fullout is offline
Old 06-25-2014, 08:24 PM
  #5001
Trader Rating: 16 (100%+)
who makes a stiffer/better front upper deck?
Mullet1 is offline
Old 06-25-2014, 08:59 PM
  #5002
symmetricon's Avatar
Trader Rating: 27 (100%+)
Xray broke in Vegas?
symmetricon is offline
Old 06-25-2014, 09:41 PM
  #5003
lol
Mullet1 is offline
Old 06-26-2014, 06:18 AM
  #5004
the incubus's Avatar
Trader Rating: 17 (100%+)
Better than that is a Spec-R fan mount. You just have to figure out what screw to use on the chassis for optimal positioning, or, you can dill a hole yourself if there is none where you wish to place the fan. A Countersunk bit will leave it looking as if it came that way from the factory.
Here it is on a 410, which is a super tight chassis to fit things into:
http://www.rctech.net/forum/12479563-post13269.html
the incubus is offline
Old 06-26-2014, 06:52 AM
  #5005
R/C Tech Elite Member
EricW's Avatar
This is what I would recommend, I haven't done it yet but I was looking at where to glue a fan the other night. If this is what others are doing I'm a little more confident that this is a viable solution.
EricW is offline
Old 06-26-2014, 07:04 AM
  #5006
Perfect, but what glue can i use?
thank you
Corde89 is offline
Old 06-26-2014, 07:26 AM
  #5007
EricW's Avatar
thank you
ShoeGoo
http://www.eclecticproducts.com/shoegoo.htm
EricW is offline
Old 06-26-2014, 07:35 AM
  #5008
elex300's Avatar
Trader Rating: 110 (100%+)
Shoo goo works great.
elex300 is offline
Old 06-26-2014, 07:43 AM
  #5009
That's not the ideal placement for a fan. The body is so close there that it doesn't pull all the fresh air it could if it had more open area behind it. I had it just like that on my 410 and it helped but someone told me I should move it away from the body for more efficient cooling and then I noticed a bigger difference. You might want to move your transponder up a bit and place the fan blowing onto the motor's end bell at an angle and the air will sweep towards the back of the body to cool more efficiently. Additionally you might want to go with a 30mm fan. That looks like a 25mm.
Shoe goo is good but you can also use the clear double sided servo tape and heat it up a bit to activate super sticky mode and it will hold the fan perfectly. Any high quality servo tape will hold it really because the fans weigh next to nothing.
Lovin' the all orange wiring.
Old 06-26-2014, 08:02 AM
  #5010
elex300's Avatar
It dropped my motor temps 20 degrees and thats all I needed. I think having it blow directly in to the opening on the can is better imo.
elex300 is offline
