Like Tree246Likes
Xray XB4 thread
Old 04-07-2013, 09:12 PM
  #2056
MX943's Avatar
Trader Rating: 41 (98%+)
Originally Posted by B00t13g
Finally finished up my wiring.
Just wondering.....why would you run the wires over the deck if there is a nice space made just for the wire underneath the deck?
MX943 is offline
Old 04-07-2013, 09:15 PM
  #2057
B00t13g's Avatar
In order to program my orion I have to remove the sensor wire out of my motor and if I run the wires under the deck it is much harder.
B00t13g is offline
Old 04-07-2013, 09:53 PM
  #2058
MX943's Avatar
Ok makes sense.
MX943 is offline
Old 04-08-2013, 11:21 PM
  #2059
B00t13g's Avatar
Anyone still using the Durango 12x1.5 o rings until the x ray ones hit the states?
B00t13g is offline
Old 04-09-2013, 03:24 AM
  #2060
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Losi 22 shock orings work better than the durango orings
Jamison R is offline
Old 04-09-2013, 06:31 AM
  #2061
Default Ball Diff's?
By the looks of the setup sheets there's a ball diff option? Does anyone have any idea of when this will be available?
jacko4309 is offline
Old 04-09-2013, 06:36 AM
  #2062
kenny lutz's Avatar
Trader Rating: 38 (100%+)
where did you get the washers you are using on the top deck and that? they look awesome wouldnt mind getting a set myself.
kenny lutz is offline
Old 04-09-2013, 06:43 AM
  #2063
B00t13g's Avatar
Better fit or what?
Team sr.
B00t13g is offline
Old 04-09-2013, 06:52 AM
  #2064
kenny lutz's Avatar
Better fit or what?
Team sr.
Thank you i found them it looks like the 3mm ones? Was you able to use the same bolts?
Old 04-09-2013, 07:02 AM
  #2065
seth556's Avatar
Trader Rating: 43 (100%+)
I found it easiest to run the sensor wire, cap wires, and battery wire though the little holder under the center drive shaft and the 3 motor wires over the top deck. I just couldn't fit all the wires through that little area and still make it look clean. It took a lot less wire to run the 3 wires over the top deck too.
seth556 is offline
Old 04-09-2013, 07:06 AM
  #2066
B00t13g's Avatar
3mm and yes.
B00t13g is offline
Old 04-09-2013, 07:16 AM
  #2067
MX943's Avatar
Amainhobby has the washers in stock.
MX943 is offline
Old 04-09-2013, 07:21 AM
  #2068
MX943's Avatar
Nice , less wire,less weight .
MX943 is offline
Old 04-09-2013, 07:54 AM
  #2069
kenny lutz's Avatar
Is one brand better than the other?
Old 04-09-2013, 08:43 AM
  #2070
MX943's Avatar
I don't think that the brand will make differentce .
MX943 is offline
