how do i make a tc3 competive on carpet?
Originally posted by fjm9898
bump
anyone have a good one for carpet, rubber tire, stock racing for my bmi chasis?
bump
SO:
1. Use the setups, or go a bit softer. But not much. Like 10wt lower on all 4 corners and one set of springs lower.
2. Slap on your rubbers and GO!
Registered User
I assume you're racing at Raincity? Chris Perry should be able to help you out. He's been racing the TC3 since it came out. I can also help you out, I ran the car for about 2 years. I'll be there on Wednesday if you want me to take a look at your car.
The TC3 is still a fast car. It should be able to hold it's own with the new cars out there...
Originally posted by lazyboy
Heres a foam tire setup from one of the A-main drivers from novak with his FT tc3.
that looks familiar. at least from the way it was worded with the camber settings.
did this come from robk by any chance?
#21
how about a detailed set-up for outdoor asphalt
take-off 27's, stock, running around a 36-100 combo
smooth, high traction
Chris08527
Chris08527
#22
bump
bump
I tried this with the rest of my setup on cs-27's today and it was only a few tenths off the foam setup.
Good luck.
Tim
#24
why is everyone saying rear tower on front. am i just not understanding it right? that means put a rear shock tower on the front right? if so why? how does it help? and would it be better to use a graphite shick tower like this? >>>> http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
#25
#26
Go to the Team Associated website. On the left side of the page scroll down to the section that says Tips and Support. From there click on setup sheets. Select on road set ups and pick the one that works best for you.
Chris Mazzola
Chris Mazzola
#27
would it be better to use a graphite shock tower like this? >>>> http://cgi.ebay.com/ws/eBayISAPI.dl...mMakeTrack=true
