Getting up to a weight limit.....
after the Nationals in NZ I notice in the stock class (540 motors +1500mah batteries) many people had to add weight to their cars to get them up to the limit.
Some had to add as much as 100+ grams (myself about 70). Just wondering if perhaps for this class only the weight limit should be reduced as some chassis don't exactly make it easy to place (or balance) all that lead?
Either that or try and find heavier parts not lighter ones. lol
Hell no not 1600......
Originally posted by ford_racing
dude, what was your weight limit?
1600g or something around that
Originally posted by Jon Kerr
The 1500 cells are probably where most of the weight is lost. Why do they run those old cells?
I'm sure that's the problem. 3300's are the heaviest cells out as far as I know. 1500 Nicd's are going to be considerably lighter and the cars are designed to be as light as possible to compensate for the heavy 3300's most people run. If they make you run those light, low capacity cells, they should lower the min weight accordingly.
or
You can do like the pros, after making the weight, you put your car down on the track and palm the weights.
Yep, you don't realise how much heavier modern cells are...
Last year I borrowed a Hpi Pro4 for my return to racing. I was using old 2000's and got quite a shock when the car was so underweight - I ran out of room on the chassis so i ended up having this long row of weights stuck down the middle of the top deck
