Xray T4 '13
#5266
#5267
I have also a couple of futabas s9550 and I can't tell the difference.
#5268
Tried two different savox last night. My sc-1251mg, and a buddies 1257tg. Car still would glitch, steering locked up for a min then would return to doing what I wanted
#5271
Checked the transmitter and no weird effects. Even drove the wgt, no issues. No on the esc but a guy traded me cash plus a gen 2 tekin (new) for my Rs pro (don't need that for 17.5blinky sedan). So I will try that next. Just sucks as there isn't much time to test besides a race event.
Took my savox apart and noticed slight white powder/charring on some of the board inside-normal? Also the bec I have is a Novak single cap. Would I benefit more going to something bigger like those 4-cap setups?
As for the car, only issue I found is the servo saver. Resistance is definitely not the same one way to the next. I find it hard to believe that this is the sole issue of my woes though.
#5272
Did you check your Rx? I've had a couple KO's take a hard hit and the clip on antenna came loose from the board inside. Pulled them apart, reattached the clip and all was well again.
#5273
#5274
Yeah, I have the RSD carpet spring kit which has the linear spring rates you listed. I actually need to put in a call to RSD as the top deck is binding badley with the layshaft pulleys and cant use the antennae mount with it. I am trying to get out there saturday. I can really use that track/test time.
#5275
Steering is as free as can be-borderline too loose. Tried two ko receivers-same issue.
#5276
Anyone have a part number for that optional aluminum servo mount with the dimple on the bottom for the chassis as well as the dimple for the top carbon piece?
#5278
I don't think the servo piece with two dimples was an option. I think it was a running change. Interesting that both the chassis and servo brace both always seemed to have a hole for it.
http://www.amainhobbies.com/product_...um-Servo-Mount
The pics still show one nub? For the price I'd consider one of the aftermarket one piece mounts and just eliminate the connection all together.
#5279
Roche racing perhaps?
#5280
...Took my savox apart and noticed slight white powder/charring on some of the board inside-normal?
2) You say resistance feels different each way, replace it now. Even if this isn't the source of your problems it sounds like it's knackered.
Skiddins
