Xray T4 '13
#4291
If anyone is interested in a like new T4, or some hop ups (ECS, gear diff, nikita outdrives) I have some for sale in the forum.
http://www.rctech.net/forum/r-c-item...l#post12325444
http://www.rctech.net/forum/r-c-item...l#post12325459
#4292
Any one use a Orion R10 in blicky stock? How do u enter the speedo into blicky mode?
#4294
Ty
#4297
- Upper bumper brace - Either the XRAY one, the one from Diggity Designs or mount a second upper bumper holder upside down on top of the other one, so that the bumper is braced against the front bulkheads.
The stock belts are fine. Belt tension is far greater a factor in drivetrain resistance than the material that the belts are made of.
#4299
and then made my changes based on the needs of the car and my driving style:
http://forum.teamxray.com/xform/inde...D=440&setup=t4
the big change for me was moving the rear arms forward (swapping the 1mm and 2mm shim on the arm).
#4300
I couldn't run the stock setup, way too much under steer, it was like driving a dump truck. Although, i do prefer to have a car with a lot of steering and very aggressive. I looked at Paul's setup for the Nationals: http://forum.teamxray.com/xform/inde...D=367&setup=t4
#4301
Low friction belts will only really help if you're either close to top speed most of the lap, or accelerating from almost a dead stop quite a lot.
