Spec-R R1
#1610
R/C Tech Elite Member
I use a Spektrum 6040 servo in my S1, it's a pretty strong servo so maybe it doesn't give much when I take a hit to the front wheels so something else gives, the rack or the servo arm.
I'd start with at least the servo saver then the rack if it doesn't hold up.
#1611
Right on, probably better safe then sorry, it'd be my luck that after talking about it the first thing I'd break is my servo haha.
I'll take a look at the different servo savers out there, not a huge fan of kimborough after the last 4 or 5 spur gears being wonky as all get out.
#1613
From what I've been told and read, there are some things you may wish to upgrade but that nothing is necessary for it to be fast out of the box. That's what made me choose this car over the sakura, seemed like people needed to change more off the bat with the sakura. I'll know more next week when i get more
#1614
I race this badboy pretty much box stock. I would go for the roll bar set. I use a ta05 set, but that's because I'm cheap and had it lying around. I also use Tc6 ball cups and ball studs on the inner camber links. Gary at 4S has those. If you end up getting the car I can help you out with setup stuff.
#1615
#1616
what toe do you guys run on this car with VTA? I have mine setup at 2.0 and I scrub a bit of speed in corners. Is 1.5 an option I ran it for a bit and did not notice much difference. Also you can achieve same toe with different combos. If I get the hinge pins to their innermost position, will it have more corner speed? Also I have an S1 with rear aluminum holders and steering, and servo mount (floating). What other upgrades for making the VTA chassis faster?
#1620
if you take the time to read a few pages back this thing has already been discussed alot already
