Which class to run onroad to improve my skills?
Hello,
I would like to begin racing electric onroad to improve my skills (reflexes, throttle control etc..). I race offroad since two years but I'm sure onroad could help me to get more finesse in my driving. I'm a smooth driver. What class would you recommend?
I would like something not too complicated but stil sensible to setup changes to understand how to set up an onroad car. If the budget could stay reasonable, then it would be even better
1/12th hands down, no question.
Cars are cheap, simple, quick, and ultra responsive. Get good at them and you will be better at everything else.
Are the foam tires more expensive to run or cheaper than rubber generally? I'm a real beginner in onroad sorry
I found in off-road that once you find a good tire for the track you race at then you are set for the season. Same thing for 1/12, see what the fast guys are using. Remember that in 1/12 it isn't point and shoot like 4wd buggy but more of a finese and maintenance of momentum through the turns.
You'll find that foams are cheaper initially to buy but, and this is a big but, they wear out fast and one set isn't enough as track conditions change. Tires are the number one major tuning item in 1/12 and if your tire set-up isn't right you will be playing catch up all day.
I would run the class with the best support. You won't learn much if there is nobody to race against.
