Mugen MTX-4
Old 10-13-2005, 07:58 PM
  #1186
BundyMan's Avatar
Originally Posted by Vinyard
Anyways as what Bundyman had mention, the MTX4 options listed on the Japanese site of Kawahara comes out in Japanese in PDF format...
so..... i think i better take up Japanese lessons soon...
Or use the many translator softwares available
BundyMan is offline
Old 10-13-2005, 08:00 PM
  #1187
rcabj's Avatar
Default race performance
hi guys.....really can't wait to see the x4 to hit the race tracks and see the performance....here, probably end of nov. should be a race held and hopefully there will be somebody with the x4 racing too...
rcabj is offline
Old 10-13-2005, 08:04 PM
  #1188
jez
jez's Avatar
here is a translation from bablefish
K-864 belt pulley (18 T)
K-857 フロントダンパースティ - doesn't tranlsate??
K-858 rear damper stay
K-860 front body mount based
K-871 roll bar mount set
K-872 roll bar
K-866 Kepler L.F.K front belt - kevlar i believe
K-867 Kepler L.F.K center belt
K-868 Kepler L.F.K rear belt
K-851 ミドルシャフトブラケッ - doesn't tranlsate??
K-852 upper arm brassiere - upper arm support?
K-853 mechanic post
K-854 brake bracket
K-855 brake bar
K-856 steering wheel saber - servo saver?
K-861 lower arm bracket
K-862 rear license plate - not sure about this one
available in november or end of november.
jez is offline
Old 10-13-2005, 08:21 PM
  #1189
Vinyard's Avatar
for us put our chassis number.. ??
Vinyard is offline
Old 10-13-2005, 08:37 PM
  #1190
Slotmachine's Avatar
This is the way the page translates for me
While the developing MTX-4 option item turn item name sale due date item turn item name sale due date K-864 belt pulley (18 T) beginning of November K-851 middle propeller strut 11 end of the month day K-857 フロントダンパースティ beginning of November K-852 upper arm bracket 11 end of the month day K-858 rear damper stay beginning of November K-853 mechanic post 11 end of the month day K-860 front body mount based beginning of November K-854 brake bracket 11 end of the month day K-871 roll bar mount set beginning of November K-855 brake bar 11 end of the month day K-872 roll bar beginning of November K-856 steering wheel saber 11 end of the month day middle of November K-861 lower arm bracket 11 end of the month day K-867 Kepler K-866 Kepler L.F.K front belt L.F.K Center belt middle of November K-862 rear license plate 11 end of the month day K-868 Kepler L.F.K rear belt middle of November in addition, in the midst of many plan and test. With circumstances of production, there are times when sale day is late more or less.
Slotmachine is offline
Old 10-13-2005, 08:39 PM
  #1191
k-851 propeller strutt.
Old 10-13-2005, 08:43 PM
  #1192
asw7576's Avatar
Originally Posted by chookgb
the belts are different rear one is wider and loose is fast
OK thanks,
loose is fast ? I just know this...... I thought medium tightness is optimum.
asw7576 is offline
Old 10-13-2005, 09:02 PM
  #1193
There is another page of mtx-4 stuff
As the continuous option MTX-3 common part for MUGEN MTX-4, you can use for MTX-4. And, in the future continuation it keeps producing and selling. The item turn item name price including tax itself price remark M-426 ベンチレーテット brake desk B 2,625 2,500 one pieces type K-710 stainless steel brake disk 1,260 1,200K-737 64 titanium F upper suspension pin 945 900K-738 64 titanium F lower suspension pin 1,050 1,000K-739 64 titanium R lower suspension pin 945 900K-761 lightweight 1 st gear housing 1,890 1,800K-762 lightweight 2st gear housing 1,575 1,500K-763 aluminum foil hub (1mm スペンサー attach) 1,890 1,800 (4 set entrances) K-765 front stubby bracket 3,465 3,300 double adjustment systems K-766 adjustable リアスタビセット 4,200 4,000K-768 & steering wheel saber 3,675 3,500 some processing the necessary K-714 brake pulley (19T) 2,100 2,000K-754 belt pulleys (24 T) 1,890 1,800 * as for K-768, please crush the screw part with the screw part of セッテイングカラー as 3mm. And, the tie rod 1 mm becomes low position. The part of other MTX-3, as soon as stock to be gone, makes waste turn.
Old 10-13-2005, 09:15 PM
  #1194
Car Breaker's Avatar
anyone know what is the price of MTX-4 in US?
Car Breaker is offline
Old 10-13-2005, 10:15 PM
  #1195
rcfoolz's Avatar
Trader Rating: 22 (100%+)
I was told $480 was street price, but Fordham Hobbies in NY has it listed for $727.98. Overseas, It is $399 euro's ($480)
Last edited by rcfoolz; 10-14-2005 at 03:09 AM. Reason: Don't want to give car a negative before its release
rcfoolz is offline
Old 10-13-2005, 10:56 PM
  #1196
Hi guys,
I believe these option parts are:
K-857 Front Damper Stay
K-851 Middle Shaft Bracket
Cheers
SNACKPACK is offline
Old 10-13-2005, 11:16 PM
  #1197
asw7576's Avatar
Is there alluminium option for center bulkhead that hold middle & front belts ?
Is it same like in mtx3 ?
I can't believe it my LHS still don't have the car yet !!!
asw7576 is offline
Old 10-13-2005, 11:46 PM
  #1198
jca2000au's Avatar
Trader Rating: 9 (91%+)
Hi... asw7576
If you are from INDONESIA you have to wait until mid NOVEMBER. As it is small market overthere.
jca2000au is offline
Old 10-13-2005, 11:52 PM
  #1199
jca2000au's Avatar
These are the list of new KAWAHARA optional parts for MTX-4. There are all in progress of developing and all will be release in mid NOVEMBER.
K-851 Middle shaft mount.
K-852 Upper arm braket.
K-853 Radio plate post.
K-854 Brake braket.
K-855 Brake lever.
K-856 Steering saver.
K-861 Lower arm braket.
K-862 Back plate.
K-864 Belt pulley (18T).
K-857 Front shock stay.
K-858 Rear shock stay.
K-860 Front body mount base.
K-871 Rollbar mount set.
K-872 Rollbar.
K-866 Kevler low friction front belt.
K-867 Kevler low friction center belt.
K-868 Kevler low friction rear belt.
Old 10-13-2005, 11:58 PM
  #1200
Originally Posted by rcfoolz
I was told today $480usd will be the street price
480?! i heard $450
this kind of price is rediculaus, for 450 i can get a decent 1/8th buggy or other car with tons of hopup and MTX-4 don't even have a CVD.
Mike, please tell us that is not true and maybe try something to avoid jack up of the price. 480 will just scare people away
$,480 i rather get a monggose and engine regarless how good the MTX-4 will be
