Mugen MTX-4
#796
Originally Posted by choisan
i bought my M11 when it was launched from rc-champ.co.jp. when i went to japan, different shops sell in different discount. typically from 20 to 30% off from list price. of course, you have to add tax and freight. And pro-s-futaba also sell overseas. from what i heard, this one is deviated from mugen staff. but price-wise, something like 5% more than typical discount. but they are specialized in kawahara too.
you may also try www.rakuseimodel.co.jp, they have an email contact [email protected]
these shops are located mostly in akihabara, where very famous in buying electronics stuff in tokyo. they are quite well in scale and set up.
or there is a hk's called rcmodel.com.hk
remember, these are FOR INFO only.
#797
Originally Posted by Scott Fisher
Weird thing was when I started buying GQ tires, I was ordering the 2deg offset. Even with the pillow balls turned in all the way, the car was still too wide. I had to run the 0 offset wheels to pass tech.
Dom
#798
yeah, that is the exact same question about stopping me buying a MUGEN for the first time.....can MTX4 use regular offset foam (0 degree) instead of those more expensive Ellegi or mugen foams...? Someone already mentioned MTX3 need to dial the pillow balls out to offset the "offset"....does MTX4 took care of that design..?
#799
Originally Posted by litespeed-dom
I run GQ exclusively and I honestly don't think they offer 2 degree offset, but then I might be wrong. I run 0 offset and have no problem obtaining desirable track width both front and rear.
Dom
Dom
#800
Originally Posted by Mike_Swauger
They are going to be a 1deg offset.
#801
Originally Posted by stefan
Offestis measured in "mm", unless you have a warped wheel, then you can have degrees.
#802
i don't use any offset tires. all i use is zero for my mtx-3 and no problem at all. i always set the car width around 198 to 199 just to be safe from tech. the threaded part of the pillow ball is pretty long. so you may pull it out to make the car wider and it will still be safe and the car will still be a tank (durable). and besides, you won't be legal anyways if you pull it too much as your car will be very wide.
#803
yeah it's not that big of deal. because i've tried both zero and the offset fast tires. as long as you set the car to the same width then you'll be ok.
#804
That's Funny Mike !!! Mean.... But damn funny !
#806
I found out if you run what mugen says to run it works out perfectly....
#807
Originally Posted by RC_Greg
Hi Guys,
Which are the best online places to get Mugen kits and spares?
thanks!
thanks!
www.gasrccar.com
Lee Muse is the man....
#808
Originally Posted by chookgb
is there a good reason for the change in rim offset as yet again the loyal mugen fast tyres runners like myself have been stung again just like the
mtx-2 to mtx-3 rim change
#809
Who is going to build MTX4 and post some photos FIRST in this forum ? The race still on except anyone who live in Japan, especially neighborhood in Chiba !!!
I suspect somebody from America is going to build and post it here first.
My LHS in Jakarta, Indonesia have ordered 8 units from Japan, but I don't know when it is coming exactly. LHS owner said October.
#810
Its not that big of deal. And oh yeah, Please use spell check!
