Mugen MTX-4
#6331
Originally Posted by tantalus007
am thinking of getting a sirio engine for my mtx4... what modifications would i need to do to my kit??? which engine mount would be better, the alum engine mount from mugen or the one piece engine mount made by kawahara??? tia...
#6332
Originally Posted by Racing4Evo
You will have to grind off some of the carb if the brake disk hits it and use a smaller ball end to avoid interference with the fuel tank under full extension of the slide.
#6334
Originally Posted by ira
I have the Sirio STI in my MTX4 with the Mugen 4mm chassis, the bottom of the case touches the chassis. I had to place small washers between the engine and engine mounts.
I have had other engines in my car and the Sirio is the only engine I had to shim up.
#6335
thanks for all the replies guys...
so most of you are running the STI versions of SIRIO engines... is there a big difference between the non STI engines???
is there a big difference in diameter size between the regular disk brake and the mugen ventilated disk brake??? my kit already came with the ventilated disk brake...
TIA...
TIA...
#6337
Ira, didn't you tell me you were planning on milling out the Mugen 4mm to utilize one piece mounts? Or was that something you were just helping Joe out with?
#6338
Originally Posted by wallyedmonds
yes like i said just run the mtx3 prospec motor mounts and it will be fine.
Tommy, I will mill the chassis to use the one piece. Do you like the pulleys I milled?
#6339
#6340
richey: so its ok to use the kyosho branded one piece alum engine mount...
Yes i have been using the Kyosho mount for about 6 months and it works great. If you want one let mem know.
#6341
Spool
Guys,
how do you make a front spool, is there a aftermarket company that has one, or what parts do I need to make spool, I tried looking at nitrohouse and I can't find the parts for making a front spool.
Thanks.
Thanks.
#6343
Hey guys, what brake pads do you recommend running with a spool on a high speed track. Something that will not fade much during a long main!
#6345
