Mugen MTX-4
#5041
what's up pat!
i saw this pic of swauger's car with your sticker on it.
#5042
Trader Rating: 27 (100%+)
man ill tell it seemed like all the mugen driver but me and a few around me were the only ones running are own bodies. i think two or three different guys ran one of mike huse's bodies thet weekend.
#5043
just like i painted for Vincent Jackson closed enough
#5044
I just Paid for Mugen MTX4
After a long fustrated time with HN Cd3 it was time too Switch MTX4 The Cd 3 have cost me more money then fun. am i Guy that like to give the underdog a chance but the Cd3 give a biggggg bill my bank manager my wife is now about to beat me up side my head,once she found out what i have done .. I would like to say to all you Mtx4 experts please help me set this car up so i justify the beating .. madbeats
ps
It was tose up between the serpent 720
but the mugen won ,, i hope i made the right choice
ps
#5046
Originally Posted by Jo Gutierrez
what's up pat!
#5047
Originally Posted by Slo-MTX4
Has anyone got a setup for a slippery track.
-37s tires
-front 59-60mm
-rear 61-62mm
(if you run a 30min main go to a 3-3.5mm split - round off edge of tire)
(if you traction roll, cut the outside edge of front tires at a 45 degree angle)
-front ride height: 5mm
-rear ride height: 6-7mm
(sounds high, but you want the car to roll more than slide)
-front spool or 50k-100k diff (I prefer spool for tight loose tracks)
-rear diff: 10k
(depending on tire wear, you may want to run a front diff)
-front springs: light blue
-rear springs: dark blue
-front droop: 2mm over ride height
-rear droop: 2-4mm over ride height
(2mm works good all around, just keep track of tire wear)
-1mm shims under front upper arms
-front toe out: -0.5
-rear toe in: 1.5 - 2.0 (any more rear toe, you'll start to push)
-front camber: 2
-rear camber: 3
Hope this helps. Oh and another good tuning aid is the clutch. If you run your clutch with a .4mm endplay, try .5mm. And for the spring nut, if you run .8, try 1mm. This should help keep you from over reving power to the wheels.
#5048
Seriously, the 720 is killer, even the RRR/Evo is still the car to beat in my eyes. But the MTX-4 ... I'm diggin it. You can almost throw it down on any track with the stock setting and school with it. I would suggest to get an aftermarket rear shock tower like Skyline and at least front universals (Mugen). Get the parts to make a front diff (Scott posted the parts you'll need). A set of dark blue springs and a 2.2 rear sway bar for tuning.
And spares, but that's a given. And thats basically all I can think of right now to help you get dialed. So that should make your wife happy.
#5049
Originally Posted by thunderbt3
Im looking into an aftermarket radio tray support (part between the engine and fuel tank. Ive looked at skyline's and shooter's and wondering if any of you guys have recommendations
Five star MTX - for 4 special part
#FS-1054SS aluminum center mount R/L set
#5050
Originally Posted by kidDynomite
Slo, try this: (starting from stock settings)
-37s tires
-front 59-60mm
-rear 61-62mm
-rear diff: 10k
-front camber: 2
-rear camber: 3
-37s tires
-front 59-60mm
-rear 61-62mm
-rear diff: 10k
-front camber: 2
-rear camber: 3
#5052
Slo, What weight oil in the rear diff?
I would go back to the one hole piston in front and try less droop in rear. If the rear springs feel too on edge for you, go with the light blue.
#5053
#5054
10K as per the kit. I had 3mm droop in the rear. I have the middle roll centre spacer in the bottom arms and 2mm spacers on the top with the inner joint in the middle hole.
