Hot Bodies TCXX
#1022
I've been running a gear diff with 1000wt oil in 17.5&13.5. I'm now racing with a 4.5 turn motor and wondered if I should a heavier oil?
Thanks in advance
Mark
Thanks in advance
Mark
#1025
I seem like I run lighter than most. I usually start with AE 60wt, then go from there. I just run as light as I can go without the car unloading the diff or doing weird things on power. I feel a thicker diff is easier to drive, but usually not as fast on tight technical carpet tracks that I'm used to.
#1028
#1032
Suspended
It was rear spacers..thx..but can't figure out center shaft..its like its too tight in aluminum mount..have to really press in..when I loosen..it works great..but when tighten bottom screws..and or top deck..center shaft get almost too tight to turn..took washers out from inside bearings..better..but still to tight
#1033
Art
