Hot Bodies TCXX
#1666
Thanks all Was running my TCXX in the street and the stock servo saver seems good and centered both ways. Noticed Andy Moore is using a direct linkage, but I'm nowhere near that skilled so I tend to hit thing more often.
#1668
Some drivers have had centering problems with this servo saver, personally, I not have any problems, work well.
You must choose the right length of the arm, for carpet I prefer 16mm, 18mm for asphalt
#1669
so you're talking about 6-8 months worth of racing EVERY day - which most of us would never do before you'd have problems..
I have the 16mm and use it on both carpet and asphalt - seems to work well for me
#1671
Ok thx for info. But with wich spindle do you use the TCX arms?? The 3 straight holes or the V2 spinde?
#1672
I used the TCXX version 1 (3 holes in line) indoors, version 2 (3rd kinked outward) outdoors. The version 2 are great, but are very fragile. I raced at a event with Andy Moore, he broke one and commented the same thing!
#1673
TCXX SET UP SHEETs
Where do I find the latest TCXX setup sheets? Found a few (e.g. Feb 2014) here, some old ones on Petite RC; but what about the recent worlds warm up? Not all of us run 4.5 motors so are there setups for something like 13.5, 17.5 and or 21.5 that the other 98% of us use?
#1674
Also I noticed in the latest setup sheets I've found that they have included the shock length (e.g., Andy Moore's is 64mm in the ones I have). In the off road world that is a measure of the droop and is measured with the suspension unweighted and from the center of the mounting screws (top and bottom). Is this the same with the TCXX and how does that relate to the droop setting on the setup sheet, which I must say doesn't seem to correlate with anything I know about RC cars?
#1677
Rear anti-squat is adjusted by adding or removing shims under the pivot blocks.
#1678
Does anyone make the TCXX steering spindles out of something beside composite material? First thing I broke was the steering spindle and in the same place I broke all the other spindles on my TC before I found some aluminum ones. However, the ones I have are only two hole design and the arm is too short (i.e., they are missing that third hole) in the TCXX arms.
