Associated RC 12 R5.2 >
Like Tree24Likes
Old 12-15-2016, 11:16 AM
  #1066
Scionara05's Avatar
I ended up running no grip on front and full rear with 43mm rear tires and 41.5 fronts with 32 ride hight all around and went to 180* on front caster and car was alot more drivable that i was putting 14 sec laps consecutively for 8 mins
Scionara05 is offline
Old 12-15-2016, 12:15 PM
  #1067
aracefan's Avatar
Trader Rating: 70 (100%+)
Nice!! I have always run my tires the other way around though... ie., I run ~41.5-41mm front and slightly smaller rears. If it works though, don't change it!
I also run about .5mm lower ride height in the rear...
aracefan is offline
Old 12-16-2016, 12:32 PM
  #1068
303slowdown's Avatar
Trader Rating: 24 (100%+)
Your the first person ive ever heard of running bigger front tires and higher front ride height. (Not saying its wrong , just never seen anyone do it ). I usually run .5 mm smaller front tire and chassis level or rear a little higher if i need a little bit more turn in.
303slowdown is offline
Old 12-17-2016, 08:01 PM
  #1069
Rugspin's Avatar
I have to agree with 303slowdown..... Aracefan not quite sure what your up too running the car that way but its defiantly not the norm.... Not saying it doesn't work for you but not how you normally setup a 1/12th scale..... Stock setups that AE has are pretty good.... Most of us run softer side springs than the Blue.... Either Green or Black... Tires small around 41.5mm to 40mm...Car around 3 to 3.5mm in height .5mm of droop Keep it simple...keep the car in stock form and it will do you well.
Rugspin is offline
Old 12-17-2016, 08:47 PM
  #1070
aracefan's Avatar
I don't know, that's just what seems to work for me. It seems to give me less "aggresive", or twitchy, steering characteristics. And your, right Rugspin, if I need a little front-end bite (without having to changes springs or anything) I just lower the front or raise the rear, to level it out. Usually all I have to do is shave my fronts down a bit.
No one should probably ever do what I do though...
aracefan is offline
Old 12-27-2016, 09:05 AM
  #1071
azeroth's Avatar
Trader Rating: 21 (100%+)
wow need to rethink what I have done abit on my 5.0+ 7 traction rolls in 4 laps is alittle excessive and still way off pace down the straights now were is that setup cheat sheet
azeroth is offline
Old 12-27-2016, 12:10 PM
  #1072
You will never be competitive on a high bite track running the front tires bigger than the rear, don't do that, it is the wrong direction.
It will do nothing but traction-role. The front will over-steer the rear, I would rethink your setup.
sdunnmcp is offline
Old 12-31-2016, 03:26 PM
  #1073
MD
MD's Avatar
Trader Rating: 136 (100%+)
I will be running on a small track with CRC black carpet in a class requiring a 13.5 motor. What gearing do you recommend?
MD is offline
Old 01-03-2017, 03:58 PM
  #1074
azeroth's Avatar
85 is a good start I think most are about 87-88 depending on combo
azeroth is offline
Old 01-03-2017, 06:30 PM
  #1075
MD
MD's Avatar
Thanks. What pinion would you recommend?
MD is offline
Old 01-05-2017, 10:17 AM
  #1076
azeroth's Avatar
Roll out 87.05
tire spur pinion
43.00 76.00 49.00
azeroth is offline
Old 01-05-2017, 10:49 AM
  #1077
MD
MD's Avatar
Roll out 87.05
tire spur pinion
43.00 76.00 49.00
Thanks.
MD is offline
Old 01-05-2017, 07:56 PM
  #1078
some87's Avatar
Trader Rating: 16 (100%+)
Hay guys sorry for the dumb question but is it possible to put in a 2s shorty in the car? My local track only allows 2s 17.5 only. I have see some other people running some small hard cases for I think 1/16th scale.
some87 is offline
Old 01-05-2017, 09:09 PM
  #1079
EDWARD2003's Avatar
Yes, there are 2s/7.4 lipos in 1s size battery cases. Not for 1/16th scale.
Can't believe people are running 2s/17.5s... I run 21.5 and that's plenty fast.
EDWARD2003 is offline
Old 01-05-2017, 11:16 PM
  #1080
some87's Avatar
If I could change it I would but it was a collective choice by everyone at the track when it opened up. I would like to have a 1s class but we don't have enough cars to split up.
some87 is offline
