Associated RC 12 R5.2
#1009
18 or 20 fronts and black or green side springs..
#1010
The hps2 silva shock built correctly does not stick.build with 10% extension,absolutely no trapped air. it may take a few tries to get right but they do work well.
#1011
What is everyone using for aftermarket diff rings and diff balls?
#1015
Measure with a ride height gauge under rear link ball.
First measure at ride height, then start lifting the chassis by the rear shock ball cup until it stops rising and the rear tires are still on your setup board. Measure it with it lifted.
Your droop is the difference between those two measurements. Race setups are usually 0.8mm to 1.2mm.
#1016
Having trouble getting my side pod links to move really freely. Rearguards of how much I play with the screw they still seem to not be as smooth as they could be. Anything I can do even if I have to get aftermarket parts?
#1020
1# https://www.youtube.com/watch?v=9zlJ4sIElN8
Center Pivot adjustment
2# https://www.youtube.com/watch?v=j5538ByMo_w
