YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 12-07-2012, 12:52 PM
  #1186
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by syndr0me
This sounds very interesting to me. So I would only need to replace the coupling with your pins and rings? The Tamiya DCJ's interfere with the c-hubs slightly, any idea how the diameter of yours compare? I'm definitely good for an order and some testing, I'd much rather not use grub screws and shrink wrap. I don't mind replacing worn parts after a few months, that's expected. It's the breaking I can't abide by.
Have you tried using a narrow inside bearing on the knuckle? this would help pull the joint away from the chub, assuming the bone is long enough to still sit well in the outdrive.
MikeXray is offline
Old 12-07-2012, 02:05 PM
  #1187
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
It's almost as if the pins are too short. They weren't breaking, just coming out during an impact. I'm gonna revisit making the Tamiya DCJ's work.
I finally broke a c-hub last night. I think I caught an axle on a flapper.
I didn't have a great night with the car to be honest. I was chasing electronics issues all night (turned out to be a sensor wire) and that kinda put me behind the curve making setup adjustments. The grip was up and I thought the car was worse for it. Pushed a bit in the sections where I needed a lot of steering. I need to spend some time working on the setup in higher traction.
Yes and yes... Pins too short. I had the dog bone fly out. Car sucks more with high grip so far. Much work needed...
hanulec is offline
Old 12-07-2012, 02:41 PM
  #1188
12scale's Avatar
My son has been running the Spec-r version 2 cv's for 3 meets now without any problems, they are cheap and have captured pins as well.
12scale is offline
Old 12-07-2012, 02:47 PM
  #1189
caltek1's Avatar
Trader Rating: 38 (100%+)
I have had no issues with the Tamiya DCJ's in boosted 17.5, which I have been running for sometime now.
BTW,
I asked Ronald's mechanic about using the forward holes on the chassis for the steering and he advised against it. Steering will be too severe was his words. I will stick to the standard position and change the inside ackerman with shims behind the ball studs.
Later,
Calvin.
caltek1 is offline
Old 12-08-2012, 02:23 AM
  #1190
Racing4Evo's Avatar
Default Good car!
I just test drove a fellow racer's brand new BD-7......AWESOME!!!
Easy to drive, almost as fast with his car w/ 17.5 than I am with my own 417X with a 13.5.
I knew the car was good, but I was surprised at how composed and balanced the handling was. Very neutral compared to Tamiya.
I am so tempted to switch right now.
Racing4Evo is offline
Old 12-08-2012, 06:11 AM
  #1191
theatriks's Avatar
I thought Nolan's car looked pretty decent in the section where he wasn't hitting things. But most cars look good on the straight.
That's awesome too hear ...mine should be arriving Monday ...can't wait !
theatriks is offline
Old 12-08-2012, 06:34 AM
  #1192
B00t13g's Avatar
The bd7 is truly an awesome car. You'll love it.
B00t13g is offline
Old 12-08-2012, 02:52 PM
  #1193
Trader Rating: 13 (100%+)
Talking
+1
It'll be interesting to put a 13.5 BL, thIS Yok currently has the track record for 17.5 TC which is the average 13.5 pace.
http://www.tqrcracing.com/
farmbridge2404 is offline
Old 12-08-2012, 06:49 PM
  #1194
theatriks's Avatar
Are they the ones that are for the bd-5?
Old 12-08-2012, 07:02 PM
  #1195
B00t13g's Avatar
Yes. Ill be ordering a set soon. Two of us that run yokomo today had issues with the yoko dcjs. Mine broke going down the straight in 17.5 blinky...
B00t13g is offline
Old 12-08-2012, 10:06 PM
  #1196
B00t13g's Avatar
Does anyone know the following bearings sizes?
Belt tensioner
Steering bell cranks
Steering center links
Or part numbers for just the bearings?
Is anyone running the tinitride coated shock shafts?
B00t13g is offline
Old 12-08-2012, 11:29 PM
  #1197
syndr0me's Avatar
Trader Rating: 32 (100%+)
Hah, it's as if we're all having issues simultaneously. Mine were fine the first day and junk thereafter.
syndr0me is offline
Old 12-09-2012, 06:02 AM
  #1198
hanulec's Avatar
Originally Posted by farmbridge2404
+1
Can u have this guy post a setup...
hanulec is offline
Old 12-09-2012, 08:01 AM
  #1199
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Hi Mike
If you having problem getting the more steering .. shorten the rear all the way.this will allow your car rotate aound the corner pretty good..
OVA is offline
Old 12-09-2012, 08:35 AM
  #1200
B00t13g's Avatar
Man, mine have been fine since the release, but idk. The metal just isn't that strong
B00t13g is offline
