YOKOMO Touring Car BD-7
#6931
the conversion kit was pretty reasonable, I chose that option for one of my '14s
#6935
Here is my set-up
#6936
If you haven't tried it yet, you could try a wider car, like 4.9/4.2 FF/FR and 6.2/2.7 RR/RF.
Most team drivers use a wide car, both in stock and mod, large/smaller tracks.
We have tested a lot with narrow/wide car, and the wide car is much more stable without loosing corner speed.
Also if traction is very high, the wider car tends to traction roll less.
#6937
#6940
Short answer, more steering. The 2015 / grey carpet liked it. The 2016 with the low CG can get steering in other ways that would roll the 2015, and the arm sweep on the '16 has been a little too much.
#6941
Front arm sweep as in not same blocks distance front to rear?
I seen more stability explained to me be have wider blocks on the Fronts blocks (FF) over the Rear Blocks (FR). Like built in toe out and adjust by the steering links accordingly to get your desired Toe Out degrees.
Anyone want to confirm this or explain if we are talking about something different?
#6942
#6943
Dear anyone, i suppose to run blinky class with old car.
So i want to ask if i want to run 20t center pulley with 34t diff, what belt(2015 or 2016) that can use, please?
Best regards
Best regards
#6944
it changes additionally Ackerman (Ackerman less efekt) and wheelbase (Less).
get more steering on carpet with FF4.2 FR4.2 is my mind with front arm sweep to much with combination LTC-R ... Mazdaspeed 6 combination FF4.9 FR4.2 i like it.
#6945
I am new to the forum and I just bought the 2016. Do you guys know how long should the shocks be without the springs on? The reason why i am asking is because without electronics and battery in it the ride height is about 11mm and i dont think the electronics will take away 6mm.
