YOKOMO Touring Car BD-7
#6903
Anybody have issues with the bearing on the gear diff's belt side getting loose? Have had my 2016 for several months now, run almost every other weekend, and 1 diff I have is so loose on the bearing that it will fall off if inverted. Same goes even with new bearings. It seems that the plastic is getting thinner every time the car is run because bearing is tight the way it should when gear diff is new.
No major accidents, no tweak, diff cams always the same level.
Never had this problem with the old size diffs on the previous BD7's i've had.
#6904
Hey all can someone advise how you make the bumper stay like in the picture with the inserts lowered? Do you sand the inserts and glue them?? Someone previously mentioned a wide super you need to buy but that does not look right.
Many Thanks
Many Thanks
#6905
So long as there is no axial play
#6906
thanks RedbullFiXX, i just find it odd that in my old BD5 and BD7 gear diffs, never had that problem and they are all still tight after years of use whereas my new 2016 diffs, even after several runs are all loose already.
Maybe they changed the material they used in the cases, or because the angle of the belt is narrower it's causing more stress on the case, I don't know, but it bothers me hahaha...
#6907
#6908
#6911
re
Hey guys,
Petite R/C should have Andrew's set-up from the ROAR Nats, which was held on the new CRC black carpet, very soon.
Our car was a missile but some bad luck took us out of contention for the win.
http://site.petitrc.com/reglages/yok...YokomoBD7.html
Hope this gives some of you a good starting point.
#6912
Corey,
Can you also look to have posted this weekend's Canadian Nats setup? I wonder how that once a year track carpet compares to the Merritton St. Catharines weekly club racing setup.
Appeared that Andrew could of won with another lap or two more time as he was reeling in Paul Lemieux very fast at the end it seemed watching the timing on LiveRC. I wish I could of raced there this year.
#6913
Hi,
Are the anti roll bars for 2015 the same for 2016?
The conversion set does not come with it, but part numbers are different.
#6914
Ok go easy on me I've been doing off road for the past 5-6 years and been trying to get into the off road reedy race for the past 2 years and failed thru the lottery system so I thought just for shits and giggles to sign up for reedy on road race and I got in so it came as a shock...I've never raced on road and I'm trying to decide on a car...I'm torn between this car and a T4 2016...obviously answers are gonna be a little bit biased due to where I'm posting this...but any imput would be helpful, as in driving characteristics and hop ups needed...thanks
#6915
re
Corey,
Check it out..
Note: Skip to 5:05
https://www.youtube.com/watch?v=kiBatw3LXZM
I will get his Canadian Nats setup posted too. Below setup is from the ROAR Nats.
http://site.petitrc.com/reglages/yok...velRC20160320/
