YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 06-24-2015, 10:29 AM
  #5896
cmunro's Avatar
Trader Rating: 12 (100%+)
Originally Posted by RedBullFiXX
interested!!!! where do you buy these?
cmunro is offline
Old 06-24-2015, 11:26 AM
  #5897
niznai's Avatar
Like it says on the box:
http://www.mibosport.com/inshop/scripts/shop.aspx
niznai is offline
Old 06-24-2015, 04:08 PM
  #5898
cmunro's Avatar
Originally Posted by niznai
Thanks but they don't show them on the site I had already looked
cmunro is offline
Old 06-24-2015, 04:44 PM
  #5899
Trader Rating: 11 (100%+)
Volker had one of these at AOC I am pretty sure. Looked a little odd seeing a servo so exposed again like they used to be!
cplus is offline
Old 06-24-2015, 04:45 PM
  #5900
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Coming soon
RedBullFiXX is offline
Old 06-24-2015, 06:46 PM
  #5901
Trader Rating: 23 (100%+)
It should be a rebranded version of this: http://www.highestrc.com/?page_id=1210
I have had one on my car for some time now but didn't really notice a difference coming from a floating bls551, it does look very nice though. The servo quality is the best i've ever had
Zhangesh is offline
Old 06-29-2015, 01:34 PM
  #5902
CristianTabush's Avatar
Trader Rating: 13 (100%+)
Back to what feels the most like home...
In the past year that I went for some soul (car) searching, (ha!) I notice there is not as many factory team settings available through places like Petit RC. I could not find a set-up with REEDY Tires, so I leave you with mine. Nothing revolutionary, part of what I love about this car is its simplicity, but I guess this car is all about the details.
I put my Yoke on the asphalt at Gulcoast this past weekend and it was a great experience. For the first time in a long time, I feel like I ran to my fullest potential on asphalt once again (let's not mention carpet).
These were the settings I used for the weekend on the way to a second place finish and fastest overall laps of the weekend. A little more practice on asphalt and I think the win could have been in the cards.
The settings include the ESC settings as well, scroll down for the Chassis. Shameless plug now: Our new definitive springs were awesome on the asphalt. I used Pink Springs all around after having tested HPI Silver, Ride Red and Silver, as well as Yokomo Pink and Blue, I settled on ours, which was a very pleasant and rewarding experience that they were the best. On carpet, I have been running our blues over the Yokomo Blue/Pink Blue/blue combo I was using before. A little more stability, keeping steering and overheating tires less.
Anyways, here is the set-ups:
https://reflexracing.3dcartstores.co...ter_Tabush.pdf
CristianTabush is offline
Old 06-29-2015, 02:26 PM
  #5903
Trader Rating: 32 (100%+)
Can someone explain where they are drilling the stock shock caps for venting? size hole? etc. Thanks in advance!
racenut123 is offline
Old 06-29-2015, 02:29 PM
  #5904
Just anywhere on the top plastic piece. I usually do it at a the vertice of the plastic piece and the shock eyelet. Usually a 1.0-1.2 mm hole will do.
Most of the time I prefer non-vented caps, but I do feel that when the grip is lower, the vent helps make the car generate a little more bite at the expense of some response.
Old 06-29-2015, 02:38 PM
  #5905
So you you suggest having both? Thanks for the explanation. Will order some springs today. The car is phenomenal. I drove a buddy's car and I had to have one, it's that good.
Old 06-29-2015, 02:44 PM
  #5906
It's one of the things I have always told my friends, whatever car it is, always keep a set of vented and a set of non vented caps. When I have run XRAY I have even plugged up the holes that already come in the shock caps from the mold. It is a very cheap option part that makes a HUGE difference.
Setting the shocks up with proper rebound is a little bit harder when they are not vented, but when they are not, you can actually play around with the amount of rebound based on how you build your shocks. With a vented cap, the shocks are easier to build, but usually getting rebound is harder.
Old 06-29-2015, 04:04 PM
  #5907
Will the yokomo aeration shock caps do the same job as drilling the hole?
Zhangesh is offline
Old 06-29-2015, 04:11 PM
  #5908
Can you run a bladder in them? They look like you can, so if you remove the screw, the concept is the same, so I think they should work.
Old 06-29-2015, 04:55 PM
  #5909
Trader Rating: 17 (100%+)
I run the Aeration Caps & they work great!
DJGonzo69 is offline
Old 06-29-2015, 09:11 PM
  #5910
mac853's Avatar
Using that holed cap on bladder can work, just for zero rebound?
mac853 is offline
