YOKOMO Touring Car BD-7
#5761
I asked pretty much the same question a few pages ago and never got an answer. Hopefully someone can chime in to help. The bd7 forum is strange. You can ask a setup question or chassis question and get no answers but an oring question will get pages of response. Go figure.
in red 2014,in black 2015.
so bulkhead holes have different spacing.
#5762
Nice. Thanks
#5763
Hi all, just about to begin my 2015 build. Any tips on building it? Currently I have:
Shocks: Black bladders (YS-8HD), 2 x blue o-rings (YS-7HG) with thin collar (BD-S2W)
Diff: As kit build specs but soaking o-rings in shock oil for a few hours first. Also sand gears down using 300 grit sandpaper
Is this correct? Much appreciated for any response.
#5764
#5765
The SSS and SLF question.
The SSS shock shaft is for the older 2013 BD7 and below and I believe is similar to the BD5 also. It is a different shock assembly compared to the SLF
The SLF is a hard anodized aluminum body that came with the 2014-2015. There may be a slight increase in volume, I don't remember. I never tried or care to swap parts between the old and new shocks. Two versions of this the standard and short and both can be used with standard touring car springs.
#5766
I read every page of this forum and exhausted Google search before asking about the chassis.
I have the blue 14 that came with blue alloy parts on the shocks. Does that mean their the sss shocks? Only reason I even care is because I want to get the tini shock shafts for them.
#5767
YS-53S-4T is the part number.
#5768
#5769
#5771
Thanks for the tips, I have dcj's, ti turnbuckles and the floating servo mount. Just completed the build though and I noticed the rear diff feels much heavier compared to other diffs. I have 3000 oil in there and it feels like a 5000?? I replaced kit red o-rings with Kyosho ORG05 and removed the smaller outer o-rings.
Also, how to people build the shocks to be zero rebound? I tried a number of different techniques that I used to do on my xray shocks but I still seem to have 10-20% rebound and there is also a tin bit of negative rebound when the shaft is fully extended.
