YOKOMO Touring Car BD-7
#4127
The xray shock cant be compared to the short Yoks. The Yok is a short version of the normal with less oil volume. The xray is bigger bore with same volume(oil) as a normal (tall) shock
#4128
#4129
I cracked a hex recently by over tightening one, I know a few others who have also done this, you do have to be a little careful with them
#4130
I've cracked a hub/hex as well on my blue BD7. Just don't over tighten them. Just a light touch is needed. I did use a Tamiya hex until my spare came in. It was a tight fit I think. Or was it loose? I forget. I'm wondering if the old style Yokomo hexes will fit? I think they were on the original BD7. They were held in place by an oring.
Moving to the short shock discussion, I ran them back to back as well on low/med bite carpet. The normal shocks ran better. You can find my post several pages back, months ago. No need to waste money on them unless if you run stock class on a high bite surface, then they might be worth a try if you have money to toss around.
#4131
Fair enough still surprised they have broken easily.
#4132
To check if you still have some clearance after doing up the wheels you can give them a tug and watch where they move. If the axle is moving in and out, then you should have some clearance between hex and bearing.
#4134
thanks for the replies about short shock issue, I cleared my mind. I have one more question: What about the steering bridge? Sometimes I use it sometimes I dont. I am wondering that when it should be used ; high or low traction? In a technical indoor or outdoor with long straights and sweepers? Should the car bend(flex) more in high grip or low grip?
#4135
Best car EVER I've loved since I first raced it.
100% better than Xray
#4136
#4137
#4138
Thanks for the replies on short shocks so far. Has anyone run them on asphalt? I run on a med to high traction asphalt track.
#4139
Please someone tell me.
Why it's different between the Protoform LTC-R body in shop and Ronald volker's PF LTC-R at ETS Race?
Where can I find Ronald Volker's PF LTC-R body?
#4140
What do you think is different about it? Looks standard to me...
