YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 02-25-2014, 07:18 PM
  #3706
Cadman1981's Avatar
Originally Posted by Captcha
Looking at the BD-7 RS kit, and am wondering if the setups from the BD-7 '14 kit would work? Looking at the 2 kits, minus bling of CF and anodized aluminum parts, I can not see where there are any differences in tuning parts, so I assume they will work.
Anyone have experience with this?
The BD7 RS is based off of the 2012/2013 BD7, because of the new chassis and motor mount, i'm not sure how well the setups would translate to the different characteristics of the RS.
Cadman1981 is offline
Old 02-26-2014, 12:43 AM
  #3707
DirkW's Avatar
On the other hand, there are (at least so far) many more setups for the "old" BD7 around, than for the 2014. And these should work for the RS - it is basically the same car, just with plastic instead of most aluminium and CF parts. And the missing sway bars of course... maybe these setups won't work 1:1, but they should be able to give you some ideas / a starting point.
DirkW is offline
Old 02-26-2014, 04:21 AM
  #3708
Aaron_M's Avatar
The setup up such as droop, ride height, camber, springs and shock build should follow the BD7 / BD7 14.
Bear in mind there are only 3 shock position holes on the shock tower of the RS, the middle ones are about right.
The RS chassis flexes way more than the standard BD7 due to the plastic components, which has a large affect on handling. It can be a bit inconsistent on carpet but more suited to lower grip asphalt.
Aaron_M is offline
Old 02-28-2014, 03:54 PM
  #3709
Cadman1981's Avatar
Originally Posted by JimmyMac
SpecR pins.
Stock pins.
I wonder how thick Roche, 3Racing, and CSO pins are?
To answer part of your question, the Roche DCJ Pins are 2.08mm - i just got mine to replace my spec-Rs V2 that were showing some wear on the pins themselves (all 17.5 racing)
Old 02-28-2014, 05:30 PM
  #3710
Trader Rating: 27 (100%+)
I've seen a lot of pictures of Volkers car in which he removes one side of the sway bar and just keeps one side attached.
A buddy of mine who runs a bd7 has been trying to get me to try this on my Xray. Any idea what removing half the sway bar mounts could do?
hyujmn is offline
Old 02-28-2014, 05:57 PM
  #3711
evochick's Avatar
it makes it totally useless like it wasnt there if you disconnect one side.
evochick is offline
Old 02-28-2014, 06:26 PM
  #3712
Well why even have them then? The article on redrc said that hes been playing with setups and messed with sway bars.
hyujmn is offline
Old 02-28-2014, 06:32 PM
  #3713
evochick's Avatar
i guess because its an easy change to make very quickly to see if it will work or not,
evochick is offline
Old 02-28-2014, 06:49 PM
  #3714
Yep, disconnecting one side of the roll bar renders it useless. For practice there's no need to remove the whole thing just to try it, just one drop link. If you don't like it, then it's much faster to replace 1 drop link than it is to replace the whole assembly.
cyclonetog is offline
Old 02-28-2014, 10:40 PM
  #3715
Racing4Evo's Avatar
You keep the sway bar on so that you don't change the weight of the car too much. Important if your close to the legal weight limit.
Racing4Evo is offline
Old 03-01-2014, 03:32 AM
  #3716
DirkW's Avatar
Simplest and quickest way to disable/enable without changing anything else, that's all.
DirkW is offline
Old 03-01-2014, 04:01 AM
  #3717
linda82's Avatar
YOKOMO Touring Car BD-7 is great my brother has one before, but that's broken by me.
linda82 is offline
Old 03-01-2014, 08:58 AM
  #3718
CanyonCarverR1's Avatar
Trader Rating: 13 (100%+)
Default Short shock conversion
What are the advantages to the short shock conversion?
CanyonCarverR1 is offline
Old 03-01-2014, 02:08 PM
  #3719
They're mainly for high grip conditions where grip roll is a problem.
If you're not grip rolling, you probably don't really need to look at them.
Old 03-02-2014, 04:52 PM
  #3720
Default Build tips
Just ordered a 2014 Black Edition, do you guys have any build tips? I know it's necessary to edge glue the chassis, but what about the shock towers, etc? I'll be running on semi-bumpy med traction asphalt.
