YOKOMO Touring Car BD-7
#2971
good 3M adhesive tape for fan will work just fine
#2972
disappointing not to see any car Yokomo the stock class, in the first ets
#2975
No because it lowers CG but adds unsprung weight.
Anything attached to the wishbone is 50% unsprung weight so fitting the shocks upside down adds the weight of the shock body, oil, bladder and shock top. vs shock bottom, shock shaft and piston.
However, some of the Serpent guys run the shocks upside down in the wet in the UK.
#2976
ok I have had my first run with the DB7 and wow just wow,
it can carry so much corner speed, and is very quick out of a corner, I am having to totally relearn how to drive compared to my old Associated 6.1.
I think it could do with some more entry corner steering but I will try going from 1000 to 2000 wt oil in the diff on the next run I think that will solve it.
I would have been at the very pointy end of the 13.5 a main if I didn't stuff up the start but still worked my way back to 4th. And I still set my fastest time of the night in the final on really worn rubber, there is nothing this car cant do... It really can make an average driver like me look good..
still smiling after last night
and yes the double sided tape held on the fan..
Beth.
Beth.
#2977
Beth.
Beth.
#2979
If you can get hold of Ride Reds or Schumacher Greens you will be very close to HPI Silver.
#2983
What would one use for med/high grip asphalt and what oils? The track temps are between 35degC to high 50's. I would really like to put a BD7 on the podium for the last round of the south African Nationals happening next weekend
#2985
Suspended
Thanks for sharing
