YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 07-26-2013, 09:38 PM
  #2521
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Has anyones tried or happy with the yokomo hard plastic shock cup with the bleeder hole...
OVA is offline
Old 07-27-2013, 07:29 AM
  #2522
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Are you referring to the drilled kit caps, or the new Aeration cap ?
RedBullFiXX is offline
Old 07-27-2013, 08:02 AM
  #2523
OVA
OVA's Avatar
sorry, I was referring the new Areation cap..
OVA is offline
Old 07-27-2013, 08:11 PM
  #2524
Have a set I've run a few times on asphalt
Very high quality bits, fit and feel is perfect
Car was very direct, and locked in, even more so than with kit caps
Downside, to get that feel, shock maintenance is high, rebuilds every run are necessary to maintain that level of performance
If you have the time between rounds, it could be worthwile
Old 07-27-2013, 10:16 PM
  #2525
OVA
OVA's Avatar
I'm glad you mention about maintain is high..now I know. Time t o rebuilt the shock again Thanks Dave
OVA is offline
Old 07-28-2013, 02:18 PM
  #2526
Cadman1981's Avatar
Don't all cars take some figuring out to find the correct setup that works for the driver? lol
Cadman1981 is offline
Old 07-28-2013, 02:19 PM
  #2527
Cadman1981's Avatar
Originally Posted by Bill K
I have never had my BD-7 running so good on an asphalt surface apart from now. This car is just beautiful to drive, and I'm able to hit every apex, and rotate the car fast enough to make those tricky corners.
I have myself an order coming in from overseas with DCJ's, springs, sway bars, shock oils/bladders and other hop-up options for this car, but I really don't want to altar the setup and ruin it's performance.
This car is the best decision I've ever made, and all I can really do is recommend this car. With the right setup, this car is driving on rails, and although it may take some figuring out to find it, it's worth it in the end!
I was refering to this post...
Old 07-28-2013, 06:22 PM
  #2528
EDWARD2003's Avatar
Do you find the Yokomo DCJ's have a lot of backlash slop. I can rotate the wheels slightly before the drive axle makes contact with the spool drive cup. Is this normal? I've only taken it out for a 2 min spin, that's all. Strange to see so much slop in newly installed drive shafts. I guess having all those pivot points in DCJ's compared to the standard axles, it would generate some slop.
EDWARD2003 is offline
Old 07-28-2013, 07:09 PM
  #2529
Racing4Evo's Avatar
Originally Posted by bukil
I loose a little of front bite and made the car push a little. I use it more of weight transfer thing than wheelbase. But thats just me.
Originally Posted by EDWARD2003
Do you find the Yokomo DCJ's have a lot of backlash slop. I can rotate the wheels slightly before the drive axle makes contact with the spool drive cup. Is this normal? I've only taken it out for a 2 min spin, that's all. Strange to see so much slop in newly installed drive shafts. Maybe this is a normal, considering all axle joints compared to the standard axles.
Yes that is normal for yokomo. Not the best metal but I haven't found it makes a difference on the track since the axle is under constant load.
Racing4Evo is offline
Old 07-28-2013, 08:35 PM
  #2530
Trader Rating: 17 (100%+)
Originally Posted by Team Speedy
I have the following in my pit box:
  • 43.5 split (std) Front
  • 41.3 split (optional) Rear
  • 42.0 split (std) Rear
For the optional parts I purchased, amongst other things:
  • YOKYS-8HD - Black Bladders
  • YOKYS-7HG - Double O-ring setup
  • YOKBD-S2W - Thin P3 O-ring for double o-ring setup
  • 6542 - HPI Blue Spring
  • 6543 - HPI Silver Springs
  • ORG05 - Kyosho O-rings for the gear diff.
  • YOKB7-203 - Floating Servo Mount
  • YOKBD-010FW - Double Cardon Joints
  • Full line of graphite suspension parts, except c-hubs.
I also have titanium turnbuckles and a few odds and ends that are nothing more then eye caddy added. However, the above is what I'd start with again if I had to repurchase this kit at a later time.
Can you elaborate on the YOKBD-S2W - Thin P3 O-ring for double o-ring setup? Is this for the shocks?
Thx.
DJGonzo69 is offline
Old 07-28-2013, 10:22 PM
  #2531
Racing4Evo's Avatar
Thx.
http://www.amainhobbies.com/product_...r-White-4-Thin
spacer is thinner to accommodate the extra o ring.
Old 07-29-2013, 10:42 AM
  #2532
Cadman1981's Avatar
Has anyone tried longer top links on their cars, front and rear? How does this affect the handling? I know it moves the roll center, but what else does it do?
I also noticed the ball stud would drive into the diff bearing retainer, so washers would be needed...
I'm looking to balance my car better, i always seem to lack rear traction on asphalt, so i'm looking for some setup ideas.
Old 07-29-2013, 11:39 AM
  #2533
Yeah I've tried it.
Like you say the ball studs don't really fit, it's a lot of messing about to make something work and my findings are that it's really not worth the effort.
cyclonetog is offline
Old 07-29-2013, 11:45 AM
  #2534
Kit build +
Gear Diff front 2.5m
1k rear diff
Rest kit setup, no shims on upper links
Should understeer with proper tires
edit:
And Hpi Silver springs
Old 07-29-2013, 02:31 PM
  #2535
Does anyone have spare parts they can sell me? I was going to get the BD7 on Wed, but Amain is back ordered on the parts I was looking for.
Yokomo Aluminum Rear-Rear Suspension Mount (Blue) (45.7mm)
Yokomo P3 O-Ring Collar (White) (4) (Thin) [YOKBD-S2W]
Kyosho Silicone O-Ring Set (P5/Orange) (10) [KYOORG05]
Yokomo Lightweight Graphite Rear Suspension Arm (39.5mm)
Thx-John
