YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 05-28-2013, 06:52 AM
  #2236
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by bukil
I have tried different combinations. If I use a smaller spur, I can't seem to get the FDR that I want since the motor will not move any further towards the spur.
My goal is to be able to use a bigger spur.
Check this post out.
That mount at AMain should be the new part, as they have just received a new stock of parts
What ratio are you looking to hit ?
RedBullFiXX is offline
Old 05-29-2013, 08:52 AM
  #2237
RC MARKET's Avatar
Trader Rating: 12 (100%+)
New upper deck was arrived !
RC MARKET is offline
Old 05-29-2013, 02:36 PM
  #2238
Does anyone know where I can buy the new version of this, which allows a better fitment of bigger pinions?
there must be a running update on this part because the version that Dave has on his car is different from the one I have. His is chamfered to allow bigger gears. I want to order the updated one. I'm worried about ordering it though because they apparently use the same part number so i have no way of knowing if it's a new or old version
DOTMAN is offline
Old 05-29-2013, 05:58 PM
  #2239
Just use the live chat feature during business hours on amain's site. Explain to them what's going on. They'll probably go out to the warehouse and put their hands on the part they have in stock, and verify whether it's the new or old, and possibly even get a new picture up. That's what they did when I asked about a schui part that had been revised. Very pleased with their service.
-Mike
grippgoat is offline
Old 05-29-2013, 07:29 PM
  #2240
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
I still have the first version and this works for me..just grind off the part where the pinion touch ....I'm using the 92T spur gear with 49T pinion which give the 3.8 FDR ... I think the 57 T pinion the biggest I can put on...
OVA is offline
Old 05-29-2013, 08:02 PM
  #2241
caltek1's Avatar
Trader Rating: 38 (100%+)
Not sure why you would want to purchase a new motor mount support when a dremel can open the area up for you. At TITC in Feb of this year I ran a 48 pitch 66 tooth spur with a 40 tooth pinion which will give a FDR of 3.3. This was the magic FDR for the 13.5 BL Hobbywing system we all used.
To get this to fit I dremeled the top and bottom of the motor support and it was good to go.
On another note since I race my BD7 on low grip netball courts and am still basically using my TITC setup. I am running yok blue springs front and rear, three hole piston, 350 weight Yokomo oil and standard shocks. I am using the 3.5 ff/fr and 2fr/5.7rr toe blocks. I have Tamiya DCJ's up front and yokomo DCJ's on the rear. I am running the plastic c hubs and the remainder of the parts are graphite.(arms, knuckles and rear hubs). I have no issues with handling. The rest of my setup is as meens yokomo setup.
I am currently running blinky 13.5 using the Trinity D3.5 motor and my car i snot much slower than a boosted 17.5.
I am very happy with the car. Tyres I am using Ride 28 blues or reds, when hotter I have been using the 32's.
Comes back to car setup and driving. I forgot to mention I do not have the steering brace fitted and I do not fit screw into the motor support through the top deck.
Just my thoughts,
Later,
Calvin.
caltek1 is offline
Old 05-29-2013, 08:06 PM
  #2242
hanzo3's Avatar
Trader Rating: 55 (100%+)
For the belt tension cam spring, what size diff ball does it use?
hanzo3 is offline
Old 05-30-2013, 02:13 PM
  #2243
Thanks for the info. i also wanted to get the new one because mine is one mil too short too. in order to use the screw, i have to use a 1 mil shim to keep my top deck from bowing
DOTMAN is offline
Old 05-31-2013, 10:10 PM
  #2244
vr6cj's Avatar
Trader Rating: 124 (100%+)
so is race and drift at 385 the best place to get a new bd7? amain is about 200 dollars more. lol, why?
vr6cj is offline
Old 06-01-2013, 06:42 AM
  #2245
NolanP's Avatar
make sure your not getting the new kit without the aluminum. the aluminum would very easy justify the 200.
Yokomo just came out with a toned down version if you will to be more cost effective.
Otherwise I'm ordering a spare kit.....
NolanP is offline
Old 06-01-2013, 07:40 AM
  #2246
That's the real deal
Same price at Pro Shop Futaba
Old 06-01-2013, 12:44 PM
  #2247
NolanP's Avatar
Ahhhh then I bet BD7x is coming out soon with lowered towers and new shocks
NolanP is offline
Old 06-01-2013, 06:45 PM
  #2248
Perhaps, but that's been the price for a while now in Japan
Shame they cost so much in HK, Europe & USA
Not sure if floating servo saver is included
Old 06-02-2013, 12:54 AM
  #2249
vr6cj's Avatar
and its worth buying from them overseas at that price. Ive ordered from them before and their airmail was here in 4 days to the US. not to mention amin charges shipping and tax for us in CA on top of the 530
vr6cj is offline
Old 06-02-2013, 01:39 AM
  #2250
CristianTabush's Avatar
Trader Rating: 13 (100%+)
It's the Dollar to Yen exchange rate. The Yen is starting to be really cheap again. You should demand your distributors and retailers to adjust their pricing.
CristianTabush is offline
