Kyosho Ultima RB6 & RB6.6 Car Thread
These hub carriers feature 0° of outboard rear toe in, and bearing inserts that allow you to use either a 5x13/5x11mm axle bearing configuration, or a 5x10/5x10 bearing configuration. Additionally, the use of bearing inserts helps to improve drive train efficiency and extend the life of the hubs.
Are those the right ones? Do you guys have part numbers
Which size do you want to use? I would use the large one.
I wanna use 5/11 and 5/13 size bearings, with aluminum ..
Why would u want different sizes?
so I can have 2 sets of hubs one for mm and rm
The larger bearings give better durability and load capacity
Naoto Matsukura has joined Kyosho for 2015... Competing in 2wd & 4wd Buggy classes. Should be pretty nice to watch...
What body and wing is good for a MM mod car? Indoor clay tracks.
The stock body is good, I know a lot of guys like the JC Finnisher body, and lately I've been running the PL Phantom body. I know some guys don't like the looks of that body, but I like it.
Wing wise, the JC high clearance or Finnisher wing seems to be pretty good. I know some guys that like the LMR wing and I've been using the PL Trifecta wing, mainly for durability.
Panda, You coming to The Clubhouse this weekend?
