Kyosho Ultima RB6 & RB6.6 Car Thread
I have heard of guys using the tapered AE pistons, does anyone have experience with this or setup sheets utilizing them?
When running the car in mid motor are you guys spacing the bottom of the rear shocks out with shims?? Looks like the spring is going to hit the turnbuckles.
Just looked at my son's car he doesn't and has plenty of clearance, but he uses v2 rear hubs with the camber link in front inside hole so that gives him more clearance.
Hey guys!
Modded my side pod plastics to take a shorty battery sideways - didn't grind the chassis down though. Is a couple mm going to make that much difference? I guess CG is going to be higher and car will roll more?
Yes it will make a difference, and should roll more. That might not be a bad thing though.
When doing the a arm mod, are you guys measuring from the center of the sway bar hole or from the side?
Is there anyone out there machining chassis for people? I have done my side pods, but I would like to mill the chassis down. Unfortunately I don't have the proper equipment to do it correctly.
Thank you to those who sent pictures of their side pods, very helpful.
Hopefully Kyosho will come out with a side ways battery chassis and side pod package.
