Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 11-03-2014, 05:02 AM
  #11026
Arghhhhhhhhhhh!!! I just ordered my RB6 and a mate's RB6 RTR today So excited!!!
Is there a quick link to Zack Rogers setup? And I heard about the driling of the rear suspension arms. Picture anywhere?
WagwanBumba is offline
Old 11-03-2014, 05:29 AM
  #11027
Johnn27's Avatar
Trader Rating: 89 (100%+)
I can post a pic later
Johnn27 is offline
Old 11-03-2014, 05:41 AM
  #11028
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Awesome! Welcome to the family! Haha. Here's the link.... Keep in mind this is only for mid motor. There's no need to drill the arms when in rear motor form since you'll already have two shock holes. I'll post a pic of my car soon... I might be a little too far up on the arm but at least they're even. And I was trying to keep the hole where there was the most plastic so I could use a longer screw. http://www.petitrc.com/setup/kyosho/...nmans20140821/
rpboggs1 is offline
Old 11-03-2014, 06:59 AM
  #11029
Thanks guys. I want to run mid-motor because it just seems to suit my driving style a bit more. The rear motor guys seem to be turning in, powersliding the rear end and powering back out of the corner, whereas I prefer a bit smoother line. Would I be right in saying that mid-motor cars are more suited for that style of driving?
Old 11-03-2014, 07:08 AM
  #11030
As long as the track is suited for it. If you're out at a loose dirt track RM will be better regardless of your driving style. Even my home track which is nice clay and misters, sometimes MM is still loose. I'm just stubborn and like my MM, I probably could have been faster with a RM car.
CaseyD is offline
Old 11-03-2014, 08:05 AM
  #11031
AlanHall's Avatar
Trader Rating: 43 (100%+)
No one has tried the extra arm hole in RM? I'm fighting for fwd bite , so I plan to next day out.
AlanHall is offline
Old 11-03-2014, 08:25 AM
  #11032
What kind of track do you run on? Hit Snyder up or try and find his rear motor set up, he never had a forward bite problem, he did have a "I can't keep my front tires on the ground" problem though.
CaseyD is offline
Old 11-03-2014, 08:28 AM
  #11033
AlanHall's Avatar
He's posted up In a Facebook discussion about giving it a shot. Im going to try that and moving my battery back more. Track is clay but I believe it has a sand mix or somthing being down near the coast. It's probably the losest track I've ever driven on.
AlanHall is offline
Old 11-03-2014, 11:47 AM
  #11034
MrHistory's Avatar
Here is the Zack Rogers Setup Sheet:
I just drilled my arms last night, so:
1: Zach says drill this hole on the arm side that already has 2 shock hole positions
2. Drill the new (3rd) hole the same distance as the first 2 holes are spaced. I measured the original 2 holes are 4.25mm apart center to center. So measure 4.25mm further in C/C and mark the arm.
3. Use the flashing line in center of the arm to find vertical line so as to drill right in the middle of arm top to bottom, with the 4.25mm in left to right.
4. I used a 2.4mm drill bit for the hole, then tapped with an M3 screw.
5. Install shocks!
MrHistory is offline
Old 11-03-2014, 04:05 PM
  #11035
Trader Rating: 357 (100%+)
Default Need help
Trying to install the Avid slipper. I used the first washer in the kit but Spurs sticks out to far.
jmoneym is offline
Old 11-03-2014, 08:31 PM
  #11036
3srcracing's Avatar
Trader Rating: 29 (100%+)
To run the avid slipper, you need to run their topshaft also.
3srcracing is offline
Old 11-04-2014, 02:42 AM
  #11037
Trader Rating: 83 (100%+)
anybody got any advice on how to remove a stud out of the aluminum rear hub? I snapped a ball stud off just leaving the stud threaded in. Thinking about drilling a small hole in the center and then see if I can back it out.
dpcardoza is offline
Old 11-04-2014, 06:43 AM
  #11038
3srcracing's Avatar
So I know you can run the RB5 arms to do prevent this but I dont have them yet.
If I land wrong or the car starts to get wrong the car get's really upset and hard to get back under control (like to much front traction) what can I do to prevent this? I currently just have the stock setup with 1.4x3/1.6 32.5/30 wt.
Old 11-04-2014, 08:51 AM
  #11039
Ran last weekend with a shorty battery all the way forward with ESC between motor and shorty pack. I was struggling for traction in MM -- B5Ms seemed to be doing well on same conditions. I do not want to go RM because I feel it doesn't fit my driving style -- besides at our track MM is the rage right now.
I am running the latest Kevin King MM setup with new drilled shock location.
Trying to get more traction I decided to run saddles all the way back against a shaved motor guard. Electronics between servo and saddles. Doing some math I have gained around 50 grams of weight and moving the saddles all the way back has changed weight distribution to the rear -- maybe?
Anyways what should I expect from this setup change? I am going in cold this weekend to a big race and would like to get a sense of what it'll behave like.
Ultimately I am looking for more rear traction and decrease steering just a tiny bit. I feel right now my RB6 oversteers coming out of turns and just feels too aggressive for my liking.
Vincent_Diesel is offline
Old 11-04-2014, 08:56 AM
  #11040
CoryD's Avatar
Have you tried MIP pucks? Gord Tessmann suggested I try them as the RB6 has a lot of dog-bone plunge which he thinks causes extra friction and fights the suspension compression on-power. I switched over to the MIPs and it was a lot better; the car actually squatted.
Give it a try.
Regards,
CoryD is offline
